Author Topic: Manual conversion  (Read 3755 times)
Shane mvsex
  • maidenhead
    • 3.0 pfl mv6 caravan
Manual conversion
« on: 23 January 2011, 14:20:47 »
Could someone help me out, I have done a search for the post on manual conversion but not found it, could someone point me in the right direction please. Also what is involved in doing the conversion?
migs and rc helicopters yeeeehaaaaaaa!
Www.omegaowners.com
Www.omegaownersnetwork.com
Re: Manual conversion
« Reply #1 on: 23 January 2011, 14:23:34 »
Steve should be able to do that with his eyes shut Shane
http://www.omegaowners.com/forum/YaBB.pl?num=1218634381
  • Auckland
    • Mazda MPV
« Reply #2 on: 23 January 2011, 14:29:57 »
Should be easy enough to find.....
Go to Omega Help Section
Follow link to Maintenance Guides
then link to Maintenance Guide Index
and scroll down to (or Ctrl-F to search for) Autobox to Manual Conversion  :y
ballcock50
  • South Wales
« Reply #3 on: 23 January 2011, 14:32:20 »
Just follow the excellent guide worked well for me :y
Shane mvsex
  • maidenhead
« Reply #4 on: 23 January 2011, 14:34:21 »
Thanks for the replies, much appreciated.
Www.omegaowners.com
« Reply #5 on: 23 January 2011, 14:39:02 »
You'll then need to do a internet search for "How to grow an Extra Leg" ...
as the correct formula is :
No of legs = no of pedals  - System Operative
If
No of pedals > no of legs - System failure.
Shane mvsex
  • maidenhead
« Reply #6 on: 23 January 2011, 14:57:59 »
 8-)
thanks lads
Www.omegaowners.com
Shane mvsex
  • maidenhead
« Reply #7 on: 13 February 2011, 12:04:58 »
anyone know which way round the spoigot bush goes into the crank ? taaa :y
Www.omegaowners.com
« Reply #8 on: 13 February 2011, 12:17:33 »
If
.. or heel and toe. :D
This lad didn't seem to do too mad with 2 feet.. I could almost forgive him for wearing white socks, in fact. :P
http://www.youtube.com/watch?v=8By2AEsGAhU
Shane mvsex
  • maidenhead
« Reply #9 on: 13 February 2011, 21:43:58 »
Lol
Got the auto fly wheel off today.
Then fitted the spigot bush and bearing.
Also fitted the manual fly wheel and clutch assembly.
And removed both down pipe/cats ready to fit the manual gearbox...
Getting there now tho
I will try and keep up dating I don't come on here much these days  :y
Www.omegaowners.com
Shane mvsex
  • maidenhead
« Reply #10 on: 15 February 2011, 14:05:24 »
Another little up date,I have now decided to fit my new 3.2 manifolds whilst the gearbox and cat pipes are out,plus the plenum is out already...
May aswell do it now  :y
Www.omegaowners.com
VX1
  • Reading, Berkshire
« Reply #11 on: 25 February 2011, 21:19:04 »
I just have a quick question regarding the Ignition timing Retard... I know that to some of you this will be common knowledge........
Ignition Timing Retard
Unplug the engine ECU and remove the connector from its hood (1 screw)
Locate the Bk/R wire on pin 42, cut off as far from pin 42 as possible (can do this further up the loom if preferred) then solder to one of the thin Brown wires and tape joint
Can someone let me know why this has to be done? Is it because the ignition setup is slightly different from the auto to manual setup?
Thanks in advance al answers greatly appreciated.
Vx Trade club card holder
Halfords trade card holder
« Reply #12 on: 25 February 2011, 21:22:27 »
Technically, the correct way is to reprogram the engine ECU, the ABS ECU and the MID.
There is an ignition retard to reduce power for gear changes.
VX1
« Reply #13 on: 25 February 2011, 21:44:49 »
So I take it you don't damage the gearbox internal then.
« Reply #14 on: 25 February 2011, 23:51:14 »
any piccies of job steps :-/
