Author Topic: Steering noise  (Read 1094 times)
megaomega123
Steering noise
« on: 03 March 2011, 16:58:22 »
I have just had track rod ends and inners changed and tracking done.
I have had noise from steering which is getting worse. I thought it was TRE's but the change has made no difference.
The noise comes from the passenger footwell and is a low pitched squeak, like a groan under strain. I was thinking top mounts but the noise is definitely passenger footwell. What parts should I be looking at? The bloke that did TRE's sprayed some lubricant in the boots which I presume are at the end of the rack, it has made no difference.
TIA
Forgot to mention that steering is normal apart from noise.
« Last Edit: 03 March 2011, 16:59:01 by phate321 »
megaomega123
Re: Steering noise
« Reply #1 on: 03 March 2011, 17:16:32 »
Just been having a read and maybe suspect the steering idler. Can anybody concur with this theory from experience?
megaomega123
Re: Steering noise
« Reply #2 on: 03 March 2011, 23:09:15 »
Bump!!
Anybody any ideas on this noise or even confirmation of idler?
Please  :)
davethediver
  • Blackburn, Lancs.
Re: Steering noise
« Reply #3 on: 03 March 2011, 23:14:14 »
Steering Idler is on the passenger side of UK cars.
P.A. Caron de Beaumarchais
megaomega123
Re: Steering noise
« Reply #4 on: 03 March 2011, 23:27:04 »
I am aware of this, I am more trying to confirm if the idler would make the kind of noise I am experiencing  :y
davethediver
  • Blackburn, Lancs.
Re: Steering noise
« Reply #5 on: 03 March 2011, 23:34:49 »
Sorry :-[ cant help you there ;)
Re: Steering noise
« Reply #6 on: 03 March 2011, 23:47:59 »
Check it for any wear then :)
« Last Edit: 04 March 2011, 08:53:44 by RobG »
Re: Steering noise
« Reply #7 on: 04 March 2011, 00:18:59 »
Jack both wheels on stands, get under there and move the road wherls by hand with steering lock off.....?
Whist lstening for the noise if course.  ;)
