Author Topic: Grease  (Read 1347 times)
amba
  • Medway towns
    • German V6
Grease
« on: 05 March 2011, 15:18:59 »
Have a bit of a noise coming from the aux belt pulley and remember seeing on the cambelt dvd,the existing pulley being repacked with grease.
Is there any recommendation of type to be used.
Re: Grease
« Reply #1 on: 05 March 2011, 15:20:57 »
what ever is in the battered old tin on the shelf at the back of your garage.  :y :y :y :y but not copperslip (Chris will get upset if you do ;D ;D ;D)
amba
  • Medway towns
    • German V6
Re: Grease
« Reply #2 on: 05 March 2011, 15:24:56 »
Suspected it was just standard high temp grease so will get my buttering knife out on Monday and see if I can shut it up a bit.
Re: Grease
« Reply #3 on: 05 March 2011, 15:30:11 »
Just be careful as you prise the dust seal out, they're easily distorted.  ;) ;)
amba
  • Medway towns
    • German V6
Re: Grease
« Reply #4 on: 05 March 2011, 15:56:51 »
Isn,t it just ..undo the large nut and lift of the metal washer (which I assume is the dust cover).Refill with grease and then do the same to the other side..being acerfull to keep the open casing flat to stop all the ball bearings falling out.
Re: Grease
« Reply #5 on: 05 March 2011, 16:02:45 »
The big washer isn't the dust seal. The pulley has a standard bearing set into the middle of it, the dust seal is the (generally) black plastic/rubber bit that sits between the inner & outer parts of the bearing.  ;)
You can do what you want to the bearing, but the balls won't fall out.  ;) ;) :y
« Last Edit: 05 March 2011, 16:03:31 by Andy_B »
amba
  • Medway towns
    • German V6
Re: Grease
« Reply #6 on: 05 March 2011, 16:07:21 »
Never opened one up so will be intersting to see what you mean...sure it will all become clear.
I expect to find an almost empty of grease bearing set .
Re: Grease
« Reply #7 on: 05 March 2011, 16:10:57 »
this is what it looks like with the cover in place
and this is a rubber ducked bearing with it removed.
Re: Grease
« Reply #8 on: 05 March 2011, 16:12:43 »
If you open up a brand new bearing you'd be surprised how little grease there is in them. You don't need to completely fill  it.  ;) ;) :y
amba
  • Medway towns
    • German V6
Re: Grease
« Reply #9 on: 05 March 2011, 16:19:41 »
Thanks Andy...very helpfull as always ..cheers
