Author Topic: MV6 Suspension  (Read 2367 times)
MV6 Suspension
« on: 26 February 2011, 19:47:23 »
Can anyone tell me if MV6 suspension will cope with the weight of a wheesel 6 cylinder lump.
I have a facelift diesel that does ok but i'd like to stiffen it up a bit and i'm breaking an MV6 so I thought I would fit the front and rear suspension.
TIA
hotel21
  • The Kingdom of Fife
Re: MV6 Suspension
« Reply #1 on: 26 February 2011, 19:50:47 »
Dont see why not.
Plod used MV6 suspension with two fat fuggers inside and a real shed load of kit in the boot and still managed to hustle them along on both straight and twisties and avoiding speed hump damage....  :)
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: MV6 Suspension
« Reply #2 on: 26 February 2011, 20:44:07 »
TIA
It will squatt some what though Youth  ;)
Tony H
  • liverpool
  • Black Elites are luurvley
Re: MV6 Suspension
« Reply #3 on: 26 February 2011, 22:14:45 »
Dont see why not.
Did that also include a few bags of donuts Broocie? ::) ;)
Sixstring
  • Lydney, Gloucestershire
Re: MV6 Suspension
« Reply #4 on: 27 February 2011, 00:54:08 »
It WILL physically fit, but will "look" a bit low and worn out.............
Re: MV6 Suspension
« Reply #5 on: 27 February 2011, 07:11:28 »
I wouldn't. Surely the TD lump is considerably heavier than the v engine?
Re: MV6 Suspension
« Reply #6 on: 27 February 2011, 07:51:50 »
Thats what I was thinking plus the straight 6 hangs over quite a bit as well :-/
Re: MV6 Suspension
« Reply #7 on: 27 February 2011, 11:22:16 »
If you want to persue it Turk had firmer springs made for his TD I believe.  :-/
Re: MV6 Suspension
« Reply #8 on: 27 February 2011, 18:08:56 »
I'm not that bothered but just thought while I had the bits sat there I might as well swap them over ;)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: MV6 Suspension
« Reply #9 on: 27 February 2011, 18:59:17 »
pete has them too !!!!   ;D ;D ;D ;D
Julian James
  • Birmingham
Re: MV6 Suspension
« Reply #10 on: 27 February 2011, 22:36:12 »
quick check:
just seeing if your MV6 has a LSD?
(always trying to keep my eye open for one ;) )
sorry for hijack...
Re: MV6 Suspension
« Reply #11 on: 27 February 2011, 23:02:54 »
quick check:
sorry for hijack...
Nope, you need an Omega Special not an MV6 for a LSD ;)
2woody
  • Northumberland
Re: MV6 Suspension
« Reply #12 on: 28 February 2011, 08:53:21 »
all three of my ex-plod cars had harder/longer springs fitted, and not MV6 springs.
you could try it as an experiment. Failing that, I'm after a set of MV6 springs, so would gladly take them off your hands.
2woody
  • Northumberland
Re: MV6 Suspension
« Reply #13 on: 28 February 2011, 08:54:24 »
quick check:
sorry for hijack...
LSD only ever fitted to police cars, not MV6. and even then, I'd estimate maybe only 20% of police cars were so fitted.
o-meg-a
  • south wales
  • avatar disabled meantime as its mahoosive!
Re: MV6 Suspension
« Reply #14 on: 05 March 2011, 18:16:50 »
bringing up an old thread i know, but this is an interesting point....
as seen here for estate:
http://www.parkers.co.uk/cars/specs/summary.aspx?model=984&page=2
And here for saloon:
http://www.parkers.co.uk/cars/specs/summary.aspx?model=985&page=2
there is a big variation in stated weights for diff spec levels and engines, but from what i can see, overall, the TD is no heavier and if anything, in some cars is lighter than the V6.
You are however correct in saying that it hangs a bit further forward, so this may affect the weight distribution.
Would be interested in actual engine block weights though.
AND also, WOW at the difference in my TD select manual estate, compared with similar Elite!
250-300kgs lighter because of all the goodies i'm missing. Kinda makes me feel better for it lol
