Author Topic: v6 inlet divider  (Read 2375 times)
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
v6 inlet divider
« on: 05 March 2011, 17:43:51 »
I have found a set of 3.0 v6 cams for my 2.5 but sadly the divider is missing from the donor engine,do I really need it??,and will it make much difference to the end result.
thanks.
Henry
« Last Edit: 05 March 2011, 21:26:49 by henryd123 »
other rides
Re: v6 inlet divider
« Reply #1 on: 06 March 2011, 02:14:10 »
The plastic bit? Thought it was the same? .... Anyone? :-/
henryd
  • west cornwall
« Reply #2 on: 06 March 2011, 10:09:14 »
I'm sure I have read on here to use the 3.0 divider,just don't know how different they are
other rides
« Reply #3 on: 06 March 2011, 10:55:27 »
They are quite a bit bigger.
« Reply #4 on: 06 March 2011, 11:15:39 »
Well there you go, so yes, you do need it.   :y
henryd
  • west cornwall
« Reply #5 on: 06 March 2011, 14:59:56 »
I shall try and find one then,saw one on eBay but thought £35+postage was a bit strong :(
other rides
amba
  • Medway towns
    • German V6
« Reply #6 on: 06 March 2011, 15:08:25 »
I never realised when first changed my cams from 2.5 to 3.0 that it was a good idea to also fit the sandwich plate from a 3.0.
Had driven about 10 k miles with upgraded cams but no increase in sandwich plate and was quite impressed with the additional performance.When sandwich plate was also changed I cannot honestly say if there is a measurable difference ,but am sure the extra size of the ports must improve the air flow,so I like to think there is an improvement.
I am sure you will feel the improvement when the cams/sandwich plate is all upgraded..only down side is I do know you will use more fuel,especially as you want to enjoy the extra "beans" you have under your Right Foot.
« Reply #7 on: 06 March 2011, 15:10:57 »
Thing is - although the plate is larger - surely you're still limited by the port size on the heads?
So, won't really get any noticible difference unless you port the inlet's on the heads?
I did this to my lovely old 2.5 (RIP) and it did fly along nicely..
