Author Topic: Oil leak  (Read 1279 times)
Jamatrad
  • Staffordshire
  • today is the start of your journey not the end
Oil leak
« on: 07 March 2011, 09:14:49 »
Can someone please direct me to typical oil leak problems on other and older threads please.
2.6,V6
Thanks
Jammy
It is the journey not the destination that shapes your life
Re: Oil leak
« Reply #1 on: 07 March 2011, 09:18:30 »
Well the most common one is the cam cover gaskets leaking oil due to the breathers not being cleaned out regularly.
If you have oil in the plug wells it is those gaskets that are leaking!
This is the OOF guide on how to fix:
http://www.omegaowners.com/forum/YaBB.pl?num=1152564281
Jamatrad
  • Staffordshire
Re: Oil leak
« Reply #2 on: 07 March 2011, 09:26:18 »
Thanks Lizzie, greatly appreciated
WINDOWMAN
  • dorset
Re: Oil leak
« Reply #3 on: 07 March 2011, 19:14:28 »
just had rocker gaskets done on my 2.5v6 but had to have oil cooler done soon after and i think oil was leaking there to... not sure if 2.6 is the same
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Oil leak
« Reply #4 on: 08 March 2011, 10:25:54 »
IME the most typical leaks are from cam covers, oil pressure switch and crank seal. Oil coolers don't typically leak outside (haven't seen one yet)  :y
Leak-wise all V6 are similar.
Re: Oil leak
« Reply #5 on: 08 March 2011, 10:38:37 »
I've seen a couple where the banjo bolts have needed nipping up.
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Oil leak
« Reply #6 on: 08 March 2011, 10:47:41 »
Yes, just remembered reading about that "feature" somewhere on the forum. I stand corrected.  :-X
