Author Topic: Alarm is driving us mad !!!!!!!!!!  (Read 3086 times)
OMEEEGAH
  • where i'm from its Omeeegah !!!!!
« on: 07 March 2011, 19:18:06 »
Ello !!
just checked the FAQ's and searched the topic as you do thats causing such frustration (and lack of sleep) and came up with a big fat zero so here goes............!
The alarm on the 03 omeeega is randomly going off,could be 1 hour 1 day or in the middle of the night and its getting to the stage where i'm going to leave it unlocked  :-/ just so i don't annoy the neighbours !!
the only other thing that has happened is the central locking is a bit iffy,sometimes it works perfect and sometimes it doesn't and also it can lock and unlock so needs the key to open and shut and another thing the drivers lock can struggle to work when all the others work fine...........its jsut like its a pain in the arse and knows it  ;D
any ideas or help would be welcomed........i thank you  :D
Where i'm from its Omeeegah
Re: Alarm is driving us mad !!!!!!!!!!
« Reply #1 on: 07 March 2011, 19:23:28 »
the bonnet switch is often a favourite, unplug it for a start & see how you go on.
Another is a failed/failing power sounder, driver's side under the plastic scuttle.
To lock the car without setting the alarm, open the rear driver's side door, push locking pin for driver's door. Check your keys are in your hand & then shut the back door.  :y :y :y
OMEEEGAH
« Reply #2 on: 07 March 2011, 19:44:41 »
Alreet cocker  :D
thats just the sort of info i'm after,i'll try locking it on the drivers door popper and then shutting the d/s rear door and then if that not works the other things.
is the power sounder under the wheelarch liner or by the wiper motor,i think its by the wiper motor but tbh i never have had any need to look before  :D
Ta very much pal  :y
« Last Edit: 07 March 2011, 19:47:37 by OMEEEGAH »
Richard A
  • Aldridge, West Midlands
« Reply #3 on: 07 March 2011, 20:24:03 »
Sorry, but it tends to be the 'rechargable batteries' in the 'POWER SOUNDER'.
It's located driver side under flap below scuttle against bulk-head, suggest - disconnect, if it sorts the problem, replace if you like or just leave it.
regards
richarda
richard a
« Reply #4 on: 07 March 2011, 20:43:01 »
Ta very much pal  :y
As Richard says, the power sounder is by the wiper motor.
The ordinary car horns are by the near side wheel arch liner/front bumper.  :y
pirate
  • westhumble surrey
    • steinmetz elit estate
« Reply #5 on: 07 March 2011, 20:46:38 »
i took my power sounder out the back plate was split and the batterys which where sealed into unit with black silicon where turning brown, so rekon i saved my motor. :y
« Reply #6 on: 07 March 2011, 20:57:26 »
regards
richarda
Not advised .... if you don't use it .. REMOVE IT !!!  Reason is .. as the batteries discharge /fail they leak acid .. this has, occasionally, been enough to short either the remaining battery or the charge circuit, and the unit has caught fire .. with expensive results.
They have done this both connected in the car and "on the shelf" ... so for safety's sake ... take it out and either replace with a new one or leave the cable bagged .. and don't put the old one anywhere that a fire would be bad ......  :(
Paddy Flannery
  • Hertford, Hertfordshire
    • 2003 2.6 V6
« Reply #7 on: 07 March 2011, 21:35:01 »
I'm having similar problems on my 2003 V6.
This bonnet sensor that can be unplugged ....... I've looked and can't find it, totally useless with anything mechnical  !!
Does anyone have a photo please ?
Thank you in anticipation.
« Reply #8 on: 07 March 2011, 21:37:25 »
stand in front of your car and it's on the left of the engine bay towards your brake reservoir .... it's the only plunger under the bonnet.  :y
Paddy Flannery
    • 2003 2.6 V6
« Reply #9 on: 07 March 2011, 21:39:58 »
So it's up by the windscreen end of the bonnet ?
I've been looking at the front by the release catch .... muppet.
Thanks. I'll have a peek tomorrow.
« Reply #10 on: 07 March 2011, 21:48:36 »
Nearer the hinge than the slam panel, but not as far back as the hinge. I can't show you mine (oooer  ::)) because mine is on the other side of the car.  :y
mantagte
  • great yarmouth
    • omega bmw maverick
« Reply #11 on: 08 March 2011, 09:17:11 »
[/quote]
i thought it was on the right
« Reply #12 on: 08 March 2011, 11:31:24 »
[/quote]
It probably is on your car as it is on mine, but the later cars have it on the driver's side of the car   :-?. There's even another connector on the passenger side where another bonnet switch cold be fitted.  :y  :y
Paddy Flannery
    • 2003 2.6 V6
« Reply #13 on: 08 March 2011, 15:55:04 »
Found it !!
After weeks of wondering where the hell it was attached to the underside of the bonnet, found it as stated next to the brake fluid reservoir. Disconnected, wire taped up and standing by.
Omeegha... have you managed to get yours sorted ?
Thanks gents.
omegod
  • liverpool
    • 2017 Seat Ateca
« Reply #14 on: 08 March 2011, 16:04:40 »
Get the powersounder removed, it's took out a few nice migs on here, 2 within one week at one point
