Author Topic: hand brake advice needed ASAP for mot  (Read 1610 times)
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« on: 10 March 2011, 08:34:29 »
help please i cant find any guides on how to replace the hand brake cable on my omega !!!!!!! i have run out of adjustment on the cable and the shoes are adjusted correctly yet i am still getting low effort and exsess travel and no reserve helpppp
2001 MV6 3.2 manual been converted from 2.6 auto
amba
  • Medway towns
    • German V6
Re: hand brake advice needed ASAP for mot
« Reply #1 on: 10 March 2011, 08:54:04 »
Look in the maintenance guide..page 4 under servicing rear and parking brakes.
It was written by MarkDTM so you can be sure it will be spot-on....best of luck with it.
bigtow
  • rochester kent
« Reply #2 on: 10 March 2011, 08:55:41 »
thanks checked that but nada about replacing cables
« Reply #3 on: 10 March 2011, 08:57:48 »
Something very wrong there then and it hints that either something is not operating, something is missing (e.g. the return springs) or its not adjusted correctly.
Although cables stretch, they dont stretch that much  :y
Follw the maintenance guide to the letter as this will easily show if soemthing is missing or faulty.  :y
bigtow
  • rochester kent
« Reply #4 on: 10 March 2011, 09:05:19 »
been advised that the cable is seized on the right had side
amba
  • Medway towns
    • German V6
« Reply #5 on: 10 March 2011, 09:31:52 »
With both rear wheels removed,can you see if the cable on both sides is moving at all when the hand brake lever is operated ?
« Reply #6 on: 10 March 2011, 09:33:18 »
Need to find out where.
Is it seized on the joint with the actuator lever (easy to sort) or in the cable sleeve (might also be easyish to sort).
Either way, if teh cable is seized then its not possible to set the system up correctly.
Do check the retrun springs are present on the rear of the backing plates to (again, easy visual check)  :y
bigtow
  • rochester kent
« Reply #7 on: 10 March 2011, 09:39:56 »
Both return springs are there i think its the cable itself. Thats had it i am going to fit a new cable and re adjust the shoes.  Any tips on cable replacement?
« Reply #8 on: 10 March 2011, 09:48:49 »
Its pretty obvious once you get under there and the heatshields are off, not to hard to do.
« Reply #9 on: 10 March 2011, 09:49:45 »
My concern is that you said its run out of adjustment on the cable.....that is not a symptom of a seized cable....
bigtow
  • rochester kent
« Reply #10 on: 10 March 2011, 10:36:54 »
Well thats what the guy who was under the car said yesterday not my self.  If i get hold of the end of the cable at the osr wheel with the disk removed. I can hardly move the cable and only the front most shoe moves does this point to a seized actuator in the drum its self?
« Reply #11 on: 10 March 2011, 14:34:05 »
No, it hints that they are not setup correctly.
My inference of what is a problem (there may be others)
The cable is at maximum adjustment, this tells me that its setup wrong and if thats the case then the rear shoes can not be set correctly. Plus, with it set so tight, you are unlikely to see any movement inti.
It needs the handbrake guide following to the letter, make sure the handbrake cable is very slack, service the brakes, and then the last thing you do, is adjust the cable (this is true of ALL handbrake setups on ALL makes).
During that process, you will soon be able to observe if there is any real cable issues (other than the fact its set wrong)
bigtow
  • rochester kent
« Reply #12 on: 10 March 2011, 16:27:18 »
Grrrrrrrrrrrr what a pita cable was seized solid new one fitted thought i better re check shoes and mechanism now i have the hand brake bit the cable pulls on in two bits and cant work out how it goes back oh and three rear brake pads have fell apart not the shoes but the main pads
bigtow
  • rochester kent
« Reply #13 on: 10 March 2011, 17:02:36 »
Handbrake shoes back together but when you work leaver only one shoe moves is this right?
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #14 on: 10 March 2011, 18:04:35 »
yes ,when the disc/drum is on the one you see moving will come up against the drum and then the other one will move as well :y
other rides
