Author Topic: coolant level  (Read 999 times)
leedsleedsleeds
coolant level
« on: 10 March 2011, 20:17:02 »
check coolant level light came on,checked bit under line so topped up,however light still on alltime is this faulty sensor or anything else thanks for help
Re: coolant level
« Reply #1 on: 10 March 2011, 20:20:36 »
Either the float has stuck down, or the sender is FUBAR.
To check float, stick a finger in the header tank (H&S Warning .. NOT when HOT) and give it a wiggle see if it "rises" and "falls"
If the float is good, unplug the wire under the header tank and short it with a paperclip. If the warning goes the sender is FUBAR.
New header tank from VX about £35, or a second hand one.. :)
Re: coolant level
« Reply #2 on: 10 March 2011, 20:20:41 »
Yes, you've a duff sensor. Cleaning out the bottle might put off the inevitable for a while,  but a new bottle is the only way.  ;) about £35 . :y
Re: coolant level
« Reply #3 on: 10 March 2011, 20:23:50 »
A sticky float is a sign of poor coolant servicing...
