Author Topic: water foundin footwell  (Read 1993 times)
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« on: 08 March 2011, 20:02:51 »
i have found water in the n/s footwell on the elite, I know you can get water on the drivers side from the matrix seals but this seem to be clean water ie no antifreeze in it any ideas anyone.
Re: water foundin footwell
« Reply #1 on: 08 March 2011, 20:04:11 »
« Last Edit: 08 March 2011, 20:05:26 by entwood »
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
« Reply #2 on: 08 March 2011, 20:07:07 »
yep, as Entwood says or you could end up with a heater motor full of water. :o
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #3 on: 08 March 2011, 20:14:21 »
Thanks to both of you will check in the morning as i have a day off at last.
Jamatrad
  • Staffordshire
  • today is the start of your journey not the end
« Reply #4 on: 08 March 2011, 20:17:36 »
I know this issue
A bit of a bugger wearing waders wilst driving  :o
It is the journey not the destination that shapes your life
Hannah Judes Dad
    • the misses round the bend
« Reply #5 on: 09 March 2011, 18:09:50 »
You should also check the pollen filter as it becomes in-effective when it has been soaked
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #6 on: 09 March 2011, 18:14:56 »
Had a good clean out today and you should see the crud i got out. It did not help with hole that plod had put behind the glove box for a cable run that is not used anymore, shame they did not cover it up after as its about 50m/m above scuttle drain and 25m/m in dia. :'( now looking for a good rubber bung.
Omega_Dan
« Reply #7 on: 09 March 2011, 18:16:25 »
I checked mine a few weeks ago and it was blocked. cleared it and changed the pollen filter and my mild steaming up issues have gone :y
« Reply #8 on: 09 March 2011, 18:46:25 »
Sadly, if a lot of water has come through the motor, be prepared for:
whining fan bearings in a few weeks
speed controller to go beserk
Worth keeping on top of the scuttle drain, moreso if you park under trees etc
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #9 on: 09 March 2011, 18:54:38 »
I just hope the water went in via the hole as it is below the filter we will have to see. next chance to have a look will be Oxford meet so I think glove box out anyone got any rubber bungs about 20-25 m/m dia.
Pitchfork
  • Tadley (near Basingrad)
  • Barndances &amp; Morris
« Reply #10 on: 09 March 2011, 18:55:16 »
If you have a sunroof & it's not the scuttle, it will be blocked drainage pipes that run from the corners
sotmh
  • london
« Reply #11 on: 09 March 2011, 20:47:35 »
had the same problem.  check drainage hole where pollen filter is.  No need to remove glove box.  Just  sure you include this in your service schedule.  Gets clogged with all sorts of crud.  will get filled up if car washed or rains:y
« Last Edit: 09 March 2011, 20:50:15 by wot »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #12 on: 10 March 2011, 16:57:30 »
I had this problem and think it was due to a leaking windscreen
Lampynoiseboy
  • SE Essex
  • pay no attention to the man behind the curtain
    • '51 3.2 Elite "Floozy"
« Reply #13 on: 12 March 2011, 01:59:13 »
How thick is the metal where the hole is? I have a whole boxful of blind grommets for electrical boxes, both 20 & 25mm. Will send you a couple if any use?
Would suggest some silicone or instant gasket to fix in with tho...
« Last Edit: 12 March 2011, 01:59:56 by Lampynoiseboy »
Trouble strikes in series of three's, but when working on the car, the next job after a series of three is not the fourth job -- it's the start of a brand new series of three
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
« Reply #14 on: 12 March 2011, 07:56:42 »
the hole is approx 50mm if it was anything like my ex-plod
just two things make sure that you clean scuttle out and dry the carpets and the underlay really well or else you will still get steaming up and quite a horrid smell fairly soon  :'(
