Author Topic: retro fitting headlamp washers to 2.2 cd  (Read 1224 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« on: 14 March 2011, 22:12:42 »
So who has fitted the above and how did you do it. Have located pump and jets. Did you add another water bottle and if yes were did you fit it. any advice helpful. Cheers in advance
Re: retro fitting headlamp washers to 2.2 cd
« Reply #1 on: 14 March 2011, 22:54:10 »
You`ll need a relay plugged in adjacent to the green 30A fuse in relay box by battery (part # 90355363). If using your existing reservoir, just to the right of windscreen pump and lower down you should see a black circle.....this is where the H/L pump sits, you`ll have to drill through the circle (unless it`s a "knock out") and fit the rubber seal  and push the pump through it
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
« Reply #2 on: 14 March 2011, 23:13:11 »
cheers
Carfix
  • Malmesbury, Wiltshire
    • 1997 & 1998 Omega Elites
« Reply #3 on: 15 March 2011, 21:38:03 »
When I added the headlamp washers to my mini-face lift (1999) CDX  I added a much bigger washer reservoir which had both pumps fitted. The reservoir bolted behind the front bumper steel beam.
I recall that the pump for the headlamp washers was much bigger?
I also found that the wiring was already there just needing a new relay to get it all working.
« Last Edit: 15 March 2011, 21:40:36 by Carfix »
« Reply #4 on: 15 March 2011, 22:17:04 »
All the same on facelifts. 6.3ltrs
