Author Topic: Bleeping.  (Read 1506 times)
Omega Man
  • Oxfordshire
Bleeping.
« on: 15 March 2011, 11:53:40 »
When I stop and turn the engine off I get four bleeps, this dosnt happen every time, only when I have try to hear where its comming from it doesn do it! ::) Any ideas? :y
Re: Bleeping.
« Reply #1 on: 15 March 2011, 11:57:20 »
Powersounder batteries on the way out. Disconnect & remove as they have been known to self-combust with dire consequences http://www.omegaowners.com/forum/YaBB.pl?num=1220198611
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
Re: Bleeping.
« Reply #2 on: 15 March 2011, 11:57:30 »
its your power sounder telling you its batteries are low, very hard to change the them unless you are electronically minded, two options
1-- get a new unit
2-- disconnect and take out- they have been known to self combust  :(
[edit]must type quicker[/edit]  :D
« Last Edit: 15 March 2011, 11:58:38 by fiend61 »
Omega Man
  • Oxfordshire
Re: Bleeping.
« Reply #3 on: 16 March 2011, 20:56:22 »
Thanks for the info, looked at the link and Ill be doing it ASAP :y
Omega Man
  • Oxfordshire
Re: Bleeping.
« Reply #4 on: 17 March 2011, 11:42:55 »
Ive got the sounder out, it bleeped once when disconnected, batteries dead :'( Does any one know whats the best way to get it apart to change the batteries, either that or it will be a new one if I can get one :y Thanks :y
twiglet
  • Norwich, Norfolk
Re: Bleeping.
« Reply #5 on: 17 March 2011, 12:54:54 »
Pretty sure they are designed as a sealed unit. New ones are about 50 quid.  :y
Re: Bleeping.
« Reply #6 on: 17 March 2011, 13:36:17 »
Send it to the local council tip, by the time they have crushed it, it will fall apart ;D
Buy a replacement, or leave without one ;)
Omega Man
  • Oxfordshire
Re: Bleeping.
« Reply #7 on: 18 March 2011, 13:15:42 »
My local garage can get one for £63.50+vat ;) Ive cut around the join and split the unit, ordered new batteries and will be fitting them £3.36+vat each, keep you posted :y
Re: Bleeping.
« Reply #8 on: 18 March 2011, 13:35:36 »
Where did you get the batteries from please ?
Omega Man
  • Oxfordshire
Re: Bleeping.
« Reply #9 on: 18 March 2011, 15:01:10 »
Fitted the batteries and refitted the sounder, tested by disconnecting it again and lots of bleeping  ;D, refitted and all is well. I got the batteries form RS components but Im sure Maplins will do them as well. :y
