Author Topic: Tinkling sound  (Read 1660 times)
Squatch
  • Belfast
Tinkling sound
« on: 21 March 2011, 10:15:30 »
Hello all, I'm hearing a strange sound from the motor..almost like someone tapping a mug with a spoon. It doesn't follow engine revs and is intermittent, almost like morse code..I'm thinking it could be ignition related - failing coil pack perhaps?
Re: Tinkling sound
« Reply #1 on: 21 March 2011, 10:17:54 »
most likey a sticking tappet, try quick few oil changers. Or some lifter treatment.
Re: Tinkling sound
« Reply #2 on: 21 March 2011, 11:08:39 »
Try the heatshields around the down pipes ;)
Squatch
  • Belfast
Re: Tinkling sound
« Reply #3 on: 21 March 2011, 12:18:55 »
Cheers - it's definately not a lifter - l know just what that sounds like from my old cdx :y I'll check the heat shields!
markrl
  • London
Re: Tinkling sound
« Reply #4 on: 21 March 2011, 13:27:54 »
I think theres a pretty good chance that your rattling will be the cat headshields. You need to get hold of a few large stainless jubilee clips to hold them in place. The headshields usually give way due to corrosion around the fixing bolts.
« Last Edit: 21 March 2011, 13:28:17 by markrl »
Squatch
  • Belfast
Re: Tinkling sound
« Reply #5 on: 21 March 2011, 13:51:46 »
Aye it'a strange one - just the lightest 'tinkling ' sound - almost like a missfire
raywilb
  • york. moved to Dalton , Thirsk
    • Citroen C4 Cactus
Re: Tinkling sound
« Reply #6 on: 21 March 2011, 13:56:29 »
i once had an annoying tinkling sound whilst the car was mobile. in my case a piggy tail from a spring jumping about that was the culprit.
Squatch
  • Belfast
Re: Tinkling sound
« Reply #7 on: 21 March 2011, 14:31:11 »
Don't know why but I've a notion this is coil pack related. The sound could be currant 'arcing' in some way...I've got spare packs so I'll swap them out and see...plus I've had a code for a high rev missfire a couple of times..
