Author Topic: Bump!  (Read 1757 times)
Aundie
  • cowdenbeath, Fife
    • 1999 2.5 Reflection
Bump!
« on: 19 March 2011, 19:06:42 »
just had a bump caught my o/s wing on a silly old cows door she opened as i was reversing past >:(.
my question is how easy are wings to replace?
  • Auckland
    • Mazda MPV
Re: Bump!
« Reply #1 on: 19 March 2011, 19:16:14 »
Front: bolt on.
Rear: part of the bodyshell.
Have a look at the for sale section for someone breaking a car in your colour if you want a front wing.
Aundie
  • cowdenbeath, Fife
Re: Bump!
« Reply #2 on: 19 March 2011, 19:57:30 »
it is a front wing  ;D at the bolt on bit may try taking it off and reshaping it then! any idea what vauxhall call their dark green paint?
Re: Bump!
« Reply #3 on: 19 March 2011, 20:03:22 »
Driver`s B pillar. Read the code http://www.omegaowners.com/forum/YaBB.pl?num=1222004987/0#0
Front wing can be removed without taking the front bumper off but it's tight.
2 torx screws attaching the arch liner to the front bumper need to come out, then the arch liner. 3 x 10mm bolts holding the black bumper retainer then the 2 x 10mm bolts behind that. Line of bolts across the top (8 IIRC and all 10mm). Then 2 x 10mm bolts behind the sill cover, 1 x 10mm bolt at the top hinge edge from the door side and 1 x 10mm bolt about halfway up the hinge edge from inside the wheel arch. Done :y
« Last Edit: 19 March 2011, 20:06:30 by RobG »
Aundie
  • cowdenbeath, Fife
Re: Bump!
« Reply #4 on: 19 March 2011, 20:10:44 »
cheers for that rob much appricated :y
Aundie
  • cowdenbeath, Fife
Re: Bump!
« Reply #5 on: 19 March 2011, 20:44:37 »
Can someone recomed somwhere to purchace a replacement wing if the needs must?
Aundie
  • cowdenbeath, Fife
Re: Bump!
« Reply #6 on: 20 March 2011, 22:52:58 »
cant add pic's?
« Last Edit: 20 March 2011, 22:53:41 by Aundie »
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Bump!
« Reply #7 on: 20 March 2011, 23:00:17 »
if it's metalic then it's krypton green. :y
but you will need to post up the paint code to be sure.
Jaguar XJ6
Aundie
  • cowdenbeath, Fife
Re: Bump!
« Reply #8 on: 22 March 2011, 19:42:37 »
getting 283. 14L as paint code. :-?
does nautilus blue look green?
Page created in 0.041 seconds with 16 queries.
