Author Topic: Turning over very fast, not start  (Read 3907 times)
billy no mates
  • Central Scotland
« on: 20 March 2011, 12:34:44 »
Went to get Sunday papers and my 2003 2.6 will not start, have not had any problems before (other than crank sensor)
It tried to fire once and now the starter is turning the engine over but too fast. It is as if there is no compression, have checked the timing belt and it is turning round OK, can see the camshaft moving in the oil filler hole also.
I replaced the belt and tensioner and water pump (all genuine) 42,000 miles ago. Car has got 134,000 miles on it, uses a little oil (1ltr every 4000 miles), uses no water.
Any thoughts before I end up elbow deep in oil/grease...
« Last Edit: 20 March 2011, 12:36:10 by nikconnor »
The Red Baron
  • burton on trent.staffs
    • 2000 chipped mv6 3.0l
Re: Turning over very fast, not start
« Reply #1 on: 20 March 2011, 12:54:32 »
now overdue another change.
you really need to check the timing aswell tbh.
  • Auckland
    • Mazda MPV
« Reply #2 on: 20 March 2011, 13:22:03 »
Have you checked for codes?
Given your description I would be taking the cam belt cover off and checking that it hasn't skipped a couple of teeth (that would be enough to lose the compression but not do any damage to the valves). You can check that using the marks on the metal cam belt cover.
The Omega does turn over pretty quickly even with good compression so it could be the crank sensor (again)
The V6 doesn't use the water pump to tension the cambelt. It only becomes a problem if it fails so catastrophically that the auxiliary belt takes the cam belt cover off
billy no mates
  • Central Scotland
« Reply #3 on: 20 March 2011, 14:03:29 »
Just got it in bits all over the drive, the belt is still whole and the marks are lining up OK.
Aux belt tensioner bearing has a bit of play (will change if i get it running)
Should have plugged the laptop in before I got the spanners out.... trust me to think the worst (must be cause im a scorpio)
« Last Edit: 20 March 2011, 14:05:50 by nikconnor »
  • Online Online
« Reply #4 on: 20 March 2011, 14:07:46 »
you can do the pedal trick on your car.  ;)
billy no mates
  • Central Scotland
« Reply #5 on: 20 March 2011, 17:46:42 »
[/quote]
you can do the pedal trick on your car.  ;)[/quote]
Showing code 1 7 10 10 .
P1700 Service Vehicle Soon Request from Transmission Control Module
Changed transmission oil and filter 10,000 miles ago. How can i reset ?
« Last Edit: 20 March 2011, 17:49:07 by nikconnor »
Martin_1962
« Reply #6 on: 20 March 2011, 18:40:26 »
Selector Switch?
I still think crank sensor
« Last Edit: 20 March 2011, 18:41:54 by Martin_1962 »
Audi_Paul
  • East Anglia
« Reply #7 on: 20 March 2011, 22:57:21 »
Flooded, happens all the time.
Cold start - short run -turn off - no restart.
Try cranking and crancking for what seem a rediculass amount of time with the throttle full down, after 30-45 secs lift off the throttle gently and it should start.
If that doesnt work, plugs oil, blast of air and a small drop of oil in each bore, and all will be well again.
« Reply #8 on: 21 March 2011, 08:10:56 »
Nah, not on fuel injection cars.
And if a car does flood, thats tells you there is an issue with something
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #9 on: 21 March 2011, 09:57:40 »
I'd be more likely to check for NO fuel at the injector rail, not too much...
  • Chatham, Kent
    • Ghastly 1.0l Focus
« Reply #10 on: 21 March 2011, 12:44:27 »
Try cranking and cranking for what seem a ridiculous amount of time with the throttle full down, after 30-45 secs lift off the throttle gently and it should start.
Flooding is VERY common on FI cars!
They're worse than carbs for it!
I see them all the time(recovery driver), and it's inevitably down to not running long enough for the cold start to cut out. I find if the battery is up to it to crank it over with the throttle open and see if it starts. Otherwise pulling the pump fuse(or tripping the pump cutoff) and then cranking it over is the way to go.
Some cars are worse for this though; Zetec engines are particularly bad, and RX8 are a nightmare.
Audi_Paul
  • East Anglia
« Reply #11 on: 21 March 2011, 19:40:58 »
Happens alot on FI cars,
especially autos.
Jaguar V8 were really know for it arround 1998-2001 model year.
My mums 2.6 omega and my 3.0 have both done it 3 or 4 times.
Seriously I never imagined there would be so many doubters out there.
Have we heard if my tip worked or not yet.
bigtow
  • rochester kent
  • 2001 3.2 MV6 manual was 2.6 auto
    • x type 2,0d estate
« Reply #12 on: 21 March 2011, 19:54:24 »
my 3.0 24v senator used to flood on a regular basis pull fuel pump fuse spin over till it fired reinsert fuse job done sorry mark
2001 MV6 3.2 manual been converted from 2.6 auto
billy no mates
  • Central Scotland
« Reply #13 on: 22 March 2011, 20:42:51 »
Stuck boost pack on it and kept turning the engine over, eventually it fired on 1 then 2 then 3 until it went on all cylinders.
Never ever came across that on a FI car before...........
Thanks to all, still got transmission error, but can live with that
  • Chatham, Kent
« Reply #14 on: 22 March 2011, 21:24:43 »
[quote
[/quote]
stuck boost pack on it and kept turning the engine over, eventually it fired on 1 then 2 then 3 until it went on all cylinders.
Thanks to all, still got transmission error, but can live with that[/quote]
 That's all the classic symptoms, and the way it starts! it's a pity that pulling the plugs is such a pain in the arse on a V6, as that's often what it takes. BMW 6 cylinders invariably need the dried off by hand to get going again.
