Author Topic: Defunct auto box (2.2 petrol Y reg)  (Read 1230 times)
KJO
  • Cork
« on: 22 March 2011, 09:24:53 »
The box box will change up from 1st if put into 1st manually. It jolts into 2nd when the gear shift is moved into drive. It then changes smoothly into 3rd, however the revs are corresponding to it being in 4th. If the the gear shift is pulled into 3rd there is no change in revs. So I suspect it goes straight from 1st to 3rd when the the gear shift is put into drive hence the jolt and then it changes smoothly into 4th. It will not change down other than moving the gear shift manualy. The torque lock appears to work as the engine turns over at 2000 rpm @ 50 mph & I am getting  26-27 mpg with rural/urban driving. Opel dealer says  box needs to be replaced. Its done 125k. It seems strange that it should be defunct with such low mileage. Anyone any ideas or should I drive it to a scrap yard. :-/
Re: Defunct auto box (2.2 petrol Y reg)
« Reply #1 on: 22 March 2011, 09:31:41 »
Fisrt thing to check is the fluid level & a possible fluid change. One of the solenoids in the box controls the change from 1st to 2nd then from 3rd to 4th (another one controls 2-3) could possibly be that one. Easy enough to change with the sump off
KJO
  • Cork
« Reply #2 on: 22 March 2011, 12:29:00 »
Fluid level ok. Its been given the tec11 treatment and they say the selector is working fine.
« Reply #3 on: 22 March 2011, 12:46:52 »
Selector may be OK, still sounds like solenoid problem
KJO
  • Cork
« Reply #4 on: 22 March 2011, 13:35:21 »
Any idea how to check the solenoid?
« Reply #5 on: 25 March 2011, 00:21:26 »
Well? not 100% sure about mine, I must have bought the worst perfect Omega there is.... >:( >:( :'( :'(
sassanach
  • trowbridge
« Reply #6 on: 25 March 2011, 17:31:17 »
remove the rear sump the 1-2 solenoid is the one nearest the side of the box,resistance should be 17.5-18.5 ohms.
                       1-2/3-4                        2-3
                   shift solenoid               shift solenoid
1ST GEAR          OFF                            ON
2ND GEAR         ON                              ON
3RD GEAR         ON                             OFF
4TH GEAR         OFF                            OFF
KJO
  • Cork
« Reply #7 on: 26 March 2011, 13:20:58 »
Many thanks for the info on checking solenoids. :y
Page created in 0.429 seconds with 16 queries.
