Author Topic: Heating isn't hot  (Read 1637 times)
Sammo
  • Salisbury
Heating isn't hot
« on: 26 March 2011, 16:55:46 »
Hi, been fiddling around all day with this heating issue, i've just about tried everything in the engine bay.
Heating is just not getting hot, I know its not the matrix blocked, I have just replaced the control valve,
There is a vacuum pipe that goes through the bulk head, right by the matrix pipes, Does anyone know where this goes to or is connected to??
I occasionally get some heating but it soon vanishes, Is this the fault or is there something else I should be giving more attention to??
I know its almost summer and won't be needing it, but want it working for next Winter  :D
Richgm
  • Tamworth
Re: Heating isn't hot
« Reply #1 on: 26 March 2011, 20:08:04 »
Does it get hot when you pull the vacuum pipe off the HBV?
Noli nothis permittere te terere
MutantCav
  • Gainsborough
« Reply #2 on: 26 March 2011, 21:04:25 »
There are 2 little pipes that run through the bulkhead...one much longer than the other...the shorter one connects into the top of the HBV...if its not then no vaccuum, no heat...
« Reply #3 on: 26 March 2011, 21:11:41 »
'Tother way round I'm afraid ... no vacuum = heat .. vacuum is used to turn it OFF .... can be proved by removing vac pipe from top of HBV (block vac pipe with a small screw to prevent a vac leak)  a serviceable system will then run hot.
Mine is running like that at the moment as I haven't had the time to replace the vac valve behind the glovebox that is stuck giving full vac at all times ... so running very cold !!! (if connected)  :)
MutantCav
  • Gainsborough
« Reply #4 on: 26 March 2011, 21:20:58 »
On my current car the pipe through the bulkhead was dangling loose and a t jct had been added from the brake servo hose outlet into the top of the HBV...no heat...
Abiton
« Reply #5 on: 26 March 2011, 21:27:40 »
If the vac pipe that should be going to the HBV is disconnected but not plugged there may be some confusing consequences.  AFAIK all the flaps that direct the air through/not-through the matrix, and to the various vents, are controlled by manifold vacuum in conjunction with solenoid valves.  If this vacuum is 'spoilt' by a hose being open-ended, who knows what the default flap positions might do?   :-/
« Last Edit: 26 March 2011, 21:30:03 by Abiton »
« Reply #6 on: 26 March 2011, 21:27:47 »
Vac pipe on top of HBV comes from one of the two valves under the glovebox pass. side
Crazycarzowner
« Reply #7 on: 26 March 2011, 21:31:29 »
I had the same problem with mine. My problem was the thermostat was stuck open. What is the water temp on the dash? with mine it took ages to move and only got to 80 deg when standing. As soon as you got on the open road it dropped, not registering. A quick visit to Elite Pete & 1 thermostat change later = nice & toasty heating.  8-)
