Author Topic: servotronic  (Read 1394 times)
fiend61
  • york
  • each to their own
    • 2.5cdx 3.0mv6 3.2vec c
servotronic
« on: 26 March 2011, 11:15:21 »
hi all
read through previous posts but couldnt find a definate answer  :(
i need to know the actual location of the servotronic relay in a 2000  mv6 3.0l auto
thanks  :y
Re: servotronic
« Reply #1 on: 26 March 2011, 12:27:08 »
MFL behind glovebox.
F/L behind cabin fusebox or driver`s kick panel, can`t remember where. :-/ (red I think)
fiend61
  • york
  • each to their own
Re: servotronic
« Reply #2 on: 26 March 2011, 17:37:48 »
its a mfl rob so up behind glovebox
thanks  :y
2woody
  • Northumberland
Re: servotronic
« Reply #3 on: 26 March 2011, 21:55:23 »
yep, lay on your head down in te footwell, loking straight up at the brake pedal. The servotronic controller is indeed red and in the stack of relays behind the fuse box.
why do you need it ?
fiend61
  • york
  • each to their own
Re: servotronic
« Reply #4 on: 27 March 2011, 00:10:53 »
mines a mfl 2woody  :y so is it as rob says up under glovebox ? im afaid i dont have dual control so no brake pedal that side  ;D
i have pretty heavy steering on the mv6 which doesnt get better with revs i have changed power steering pump for a known good one but no difference  :(
 i was looking at changing servotronic relay just to see whether that made a difference before i get a tech2 on it to see what setting it is at  ;)
fiend61
  • york
  • each to their own
Re: servotronic
« Reply #5 on: 27 March 2011, 16:23:35 »
hi all
right taken glovebox out and can only see 3 relays, 2 white ones with bosch written on one of them and a orange one fairly big,
on the drivers side after taking cover off under fusebox 2 relay bases fell out but only one relay in one base and i cant see a red relay anywhere  :(
could this be the problem that someone has already taken the relay out ??? and am i right in saying that without relay in you get minimum assistance ??
« Last Edit: 27 March 2011, 16:24:54 by fiend61 »
fiend61
  • york
  • each to their own
Re: servotronic
« Reply #6 on: 27 March 2011, 16:50:45 »
ok have now found the servotronic relay  :y
thanks to robg  :y
yes it is under glovebox in a mfl  :y
must really get my eyes tested either that or i am colour blind  8-) :o :o 8-)
the orange relay was indeed red in the light of day  :y
so once again cheers robg for the help and errr patience  :y
Re: servotronic
« Reply #7 on: 27 March 2011, 16:56:58 »
thanks to robg  :y
No probs mate 8-) :y
Page created in 0.012 seconds with 14 queries.
