Author Topic: Wobble\vibration on steering?  (Read 1649 times)
robg1984
  • immigham n.e.lincs
« on: 22 March 2011, 20:16:23 »
Hi all i had a vibration on the driver side which i thought was a result of a knackered wheel bearing as there was a fair bit of play in it! Its now changed and tightened up correctly but the vibration is still there just wondering if anyone can give me any suggestions what it is/where i need to look :y
tia
rob
Aundie
  • cowdenbeath, Fife
    • 1999 2.5 Reflection
Re: Wobble\vibration on steering?
« Reply #1 on: 22 March 2011, 20:19:03 »
warped disc?
Aundie
  • cowdenbeath, Fife
« Reply #2 on: 22 March 2011, 20:22:13 »
wheel may just need balanced, could be tyre fault i remember changing a cv joint on a caviler and it ended up being a bulge on the inside wall of the tyre.
robg1984
« Reply #3 on: 22 March 2011, 20:22:27 »
thanks for the reply :) i was thinking this but the vibration starts to get noticeable at about 45mph would it be constantly there if it was a warped disc?
« Reply #4 on: 22 March 2011, 20:36:10 »
Tends to be out of balance as suggested
robg1984
« Reply #5 on: 22 March 2011, 20:59:42 »
thanks ill have a look tomorrow after work and order some discs if its out :y
Aundie
  • cowdenbeath, Fife
« Reply #6 on: 22 March 2011, 21:08:20 »
go to a tyre fitters first,get the wheel checked for balance will only cost pennies.
« Reply #7 on: 22 March 2011, 22:09:12 »
Wobble, side to side, ime is Play in the steering, wishbone bushes worn baring, steering idler type stuff. Can be random.
Vibration, up and down, wheel or tyre out of round or balance, disc could be off centre or damaged but usually shows when braking.
Ime....
Hth
robg1984
« Reply #8 on: 28 March 2011, 18:29:11 »
cheers for all the help guys ive definatly got a warped disc so there goin to be changed which was a job i was working towards anyway :y
