Author Topic: Diesel Starting Trouble  (Read 1609 times)
dustybin
« on: 27 March 2011, 13:51:23 »
Vauxhall Omega 2.0 DTI Well got new diesel pump ouch, fitted primer pump, changed injector pipes, its trying to start but just won't ignite. any ideas
Omegatoy
  • UK
Re: Diesel Starting Trouble
« Reply #1 on: 27 March 2011, 19:02:27 »
tow it bud, sometimes its the only way with the dti
« Last Edit: 27 March 2011, 19:03:26 by Omegatoy »
Brikhead
  • West-Mids.
  • Sleeping. Do not disturb.
    • 2003 chitroen Saxo
« Reply #2 on: 27 March 2011, 19:41:48 »
Any fault codes present, ones that aren't related to the fuel pump!?
Also you could try Easy Start, just to confirm it is a fuel problem.
« Last Edit: 27 March 2011, 19:42:15 by brikhead »
dustybin
« Reply #3 on: 27 March 2011, 22:05:34 »
I've tried towing it, It's about to fire up but does'nt. just keeps trying to start after that when turning engine over.
Omegatoy
  • UK
« Reply #4 on: 28 March 2011, 07:50:50 »
had 2 that needed towing for over a mile before they fired up, how far did you tow it? had to use a transit van as it was the only thing that could keep pulling it!!
hoofing it
« Reply #5 on: 28 March 2011, 19:10:39 »
Also you could try [size=7]Easy Start[/size], just to confirm it is a fuel problem.
Carb cleaner is better not as adictive :-*
Road Hog Mad
  • Cheshire
« Reply #6 on: 28 March 2011, 19:16:51 »
bleed the system?
Brikhead
  • West-Mids.
« Reply #7 on: 28 March 2011, 22:03:08 »
bleed the system?
How? There is no official bleeding procedure for these pumps, the system is meant to be self priming. You could try loosening the fuel feed to the injector furthest from the pump but it probably won't help.
Best thing to do is make sure the fuel filter bowl is full of fuel and then operate the starter in 10-15 second bursts, allowing time for the starter motor to cool before cranking again. After around 4 cycles you'll need to fill the fuel filter back up and start again. This may not help if the pump timing is out or the pump is still brokended...
dustybin
« Reply #8 on: 28 March 2011, 22:21:52 »
got it started changed like an inlet valve with breather pipe goes into like a throttle linkage to take in air. dont know what it's called but very smokie. any ideas.
