Author Topic: Rear discs V6  (Read 1130 times)
Rear discs V6
« on: 28 March 2011, 23:14:38 »
Am I right in thinking the v6,s were all fitted with vented rear discs, or is my memory playing up again ? :-/
« Last Edit: 28 March 2011, 23:15:02 by albitz »
Re: Rear discs V6
« Reply #1 on: 28 March 2011, 23:17:27 »
No & yes!  ;D ;D
The very last V6s had vented but otherwise had solid.  :y
Re: Rear discs V6
« Reply #2 on: 28 March 2011, 23:20:35 »
Thanks Andy. I noticed mine were solid today, and thought it had the wrong discs fitted. Couldnt remember what was on my old one. ::)
CaptainZok
  • Bolton
  • Victim of Cyberbullying.
    • 3.2 MV6 Estate
Re: Rear discs V6
« Reply #3 on: 28 March 2011, 23:32:05 »
Not unless you've been to the garage Mick Dundee used to get his changed.
TuBy's new whipping boy.
Re: Rear discs V6
« Reply #4 on: 28 March 2011, 23:37:39 »
These are the kind of garages that shouldn't be trading.   >:(
Re: Rear discs V6
« Reply #5 on: 29 March 2011, 08:58:52 »
Vented on V6 from 2001 onwards (not sure if it exactly ties in with 2.6/3.2 engines)
Re: Rear discs V6
« Reply #6 on: 29 March 2011, 09:26:50 »
I think I was getting befuddled with early 2.0 fronts - they were solid iirc. :-[
Re: Rear discs V6
« Reply #7 on: 29 March 2011, 09:28:04 »
Nope, all Omega fronts are vented. 2.0 up to 1997 were only 286mm diameter.
Re: Rear discs V6
« Reply #8 on: 29 March 2011, 09:34:20 »
My memory is getting rather shocking. :-[ ::)
« Last Edit: 29 March 2011, 09:34:38 by albitz »
kcl
  • Finland
    • Volvo V60 D4 -14
Re: Rear discs V6
« Reply #9 on: 29 March 2011, 09:48:32 »
IIRC in TIS it says that the vented rear discs were introduced with 2,6/3,2 engines. However, I have seen at least two Omegas (Opel though...  :-/) that have 3,0 engine and vented discs in the rear...
Cliffo B
  • Leeds West Yorkshire
    • 03 3.2 Elite Estate
Re: Rear discs V6
« Reply #10 on: 29 March 2011, 11:22:24 »
For the record my Miggy has vented rear discs,which I replaced with Mintex 18 months back and have had no problems,but the calipers are a different story as they are a now a non serviced product. All there is available are remanufactured ones the standard of which leaves a lot to be desired,especially the integrity of the castings as they are  subject to harsh corrosive winter road spray.
