Author Topic: Drain plug  (Read 1422 times)
mahony
  • london
    • omega elite 3.0
Drain plug
« on: 30 March 2011, 07:27:49 »
I seem to have a drip from my radiator drain plug ( did a coolant change a few weeks back ) ,i have done it up quite tight and did not want to tighten any further in case i break it as it's plastic,do they have a  rubber seal on the plug ?
Re: Drain plug
« Reply #1 on: 30 March 2011, 08:16:37 »
Yes, they have two satndard rubber O rings.
Tightening it further makes little difference (other than it might seal on the metal washer a bit.
Re: Drain plug
« Reply #2 on: 30 March 2011, 09:54:03 »
As said, two O rings. All you'll do is break something by over tightening.  ;)
mahony
  • london
    • omega elite 3.0
Re: Drain plug
« Reply #3 on: 30 March 2011, 09:57:49 »
Thanks chaps  :y
Re: Drain plug
« Reply #4 on: 30 March 2011, 12:01:32 »
Be careful as you can break it if you over tighten it! As I found out..... ::)
