Author Topic: A bit more advice needed  (Read 1017 times)
Marc Taylor
  • Essex
« on: 30 March 2011, 20:25:51 »
I am half way through changing my wishbones got the nearside to do tomorrow if it doesnt rain again.  I tried changing the oil and think i may have rounded off the plug, could i get it off with big pliers or something? Has anyone else managed this? And failed miserably on changing the fuel filter, I cant work out how it come off so any advice would be greatly appreciated
Cheers
amba
  • Medway towns
    • German V6
Re: A bit more advice needed
« Reply #1 on: 30 March 2011, 20:35:23 »
If you have rounded off oil drain plug the best solution would be to buy a replacement plug with washer first.
Removal may be possible with a very tight grip from a set of molegrips to slacken off then carefully  take out with waterpipe pliers to avoid stressing the sump.
Fuel filter can be fiddly and is far easier with purpose made pliers.At each end of the filter is a small plastic clip which requires both small tangs compressing and then pulling off the pipe.Not too hard with 2 small screw drivers to press down but you then need a 3rd hand to pull off the pipe.If you have bought a new fuel filter worth buying the 2 small clips incase the existing ones get damaged..only a few pence and better to be safe.
Marc Taylor
  • Essex
« Reply #2 on: 30 March 2011, 20:40:31 »
Thank you amba, first thing in the morning is another trip to the local vx spares place
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #3 on: 30 March 2011, 20:44:39 »
You can get from places like Machine Mart sockets that removed Rounded Bolt Heads. They tighten on the Bolt Head whilst undoing :D
Hope that makes sense but they are brillant :y
Marc Taylor
  • Essex
« Reply #4 on: 30 March 2011, 20:51:13 »
I know what you mean but the plug on mine is a torx bit.  I tried turning it and it slipped and all other pieces i used just did the same. Can you get the bolt plug? Ill have to get myself one of them if i can find one of them.
