Author Topic: front vac reservoir  (Read 1957 times)
geoff
  • thornaby,stockton on tees
front vac reservoir
« on: 31 March 2011, 17:12:08 »
can some one tell me on the front vac res for multi ram,which was the larger connector,looking from above the left or the right one,one of mine was broke and was glued back on the rubber pipe and both look the same size,just asking as checking all the multi ram pipes are on right :y :y :y :y :y
geoff
Re: front vac reservoir
« Reply #1 on: 31 March 2011, 19:38:14 »
anybody know would help loads :) :) :) :y :y :y :y
Bent valve
« Reply #2 on: 31 March 2011, 20:05:55 »
I dont know. but i do know that the res near the pollen filter is the same and is usally intact as it does not get hasseled as much as the front one. have a look at that and see which is the larger pipe.
