Author Topic: clutch and sump help needed please  (Read 825 times)
wardy
« on: 31 March 2011, 21:42:52 »
hello all ive started to rebuild my old xev turbo and its going to be going in to an omega ive not got the car yet to compear things so hoping you guys can help my engine come out of a vectra and im pretty sure the sump and pick up pipe are driffrent for an omega were it is rwd ??? and now the bit im realying having hassle with the engine should be pushing some good power and am in need of a paddle clutch does any one no were i could get one from for the omega box would a f28 one fit and would i be best off running a flat or potted flywheel any help would be great
sierrapaul
Re: clutch and sump help needed please
« Reply #1 on: 01 April 2011, 09:10:01 »
i think you will need the sump and pick up pipe from a 2 litre 8 valve carlton or 1.8 manta.use a c20xe flat fly wheel.as for the cluth it depends on what gearbox your going to use as the splines on the input shat are not all the same.so ues clutch plate and cover that matchs the gearbox your going to use.paul
