Author Topic: Idle: surging up and down.  (Read 1503 times)
Debs.
« on: 27 March 2011, 21:04:19 »
I`ve noticed recently that the normally smooth idle on my `99 2.5 V6 will sometimes drop then immediately surge up to (circa) 800-900 rpm, then settle back to normal.....often, it`s only once or twice at traffic lights during a journey.
There are no codes showing and in all other respects the car drives and responds smoothly; as per usual.
Would the idle-valve be a likely suspect?......if so, may it be cleaned/serviced?  :-/
davethediver
  • Blackburn, Lancs.
Re: Idle: surging up and down.
« Reply #1 on: 27 March 2011, 21:09:49 »
Possibly Miss Debs or maybe an air leak somewhere :-/
P.A. Caron de Beaumarchais
gstylebaby
  • stockport
« Reply #2 on: 27 March 2011, 21:22:24 »
Would the be a idle-valve be a  likely suspect?......if so, may it be cleaned/serviced?  :-/
It could be debs i cleaned mine out with i.p.a but double check with someone who is more in the know than me....It has not damaged mine any. :y
« Last Edit: 27 March 2011, 21:23:23 by gstylebaby »
davethediver
  • Blackburn, Lancs.
« Reply #3 on: 27 March 2011, 21:32:31 »
Will any other bitter do :D ;D ;D
« Reply #4 on: 27 March 2011, 22:25:31 »
idle valve , soak in injector cleaner or thinner let rest for some hours then clean by shaking (filled with cleaner) in every direction.. open its valve and clean around as much possible.. :y
ps: if you have egr and not blocked it (with metal) clean it with wd40 not thinner..
« Last Edit: 27 March 2011, 23:07:57 by cem_devecioglu »
hotel21
  • The Kingdom of Fife
« Reply #5 on: 27 March 2011, 22:52:24 »
I would be blaming the idle control valve...  ;)
Debs.
« Reply #6 on: 27 March 2011, 23:09:43 »
Thank you for the replies, chaps! :y
.....I will pull the valve, give it a Spring clean and report back. ;)
« Reply #7 on: 27 March 2011, 23:12:25 »
even brand new icv s needs cleaning after some time and from time to time Debs..  :y
STRAWB
« Reply #8 on: 28 March 2011, 10:38:48 »
Glad you ve posted this one Debs. Sounds like the exact same issue I have with my 2.0 GLS. Always on a cold engine and always in stop start traffic it idles above and below 1000rpm erratically and when Ive needed to apply my handbrake and got to Park (I have an auto) it will rev up to 2500 rpm with no assistance from me!! Very worrying  :o Any thoughts peolpe. Does this sound like the same beastie or something else. Thanks  :y
amba
  • Medway towns
    • German V6
« Reply #9 on: 28 March 2011, 12:36:20 »
Un-metered air getting in somewhere.
Check all pipes for splits and also worth going around the top of the engine with some carb cleaner.Give it a gentle spray on all metal/metal joins and around air pipes to see if engine speed increases.If this does happen you have found the source of the air leak as carb cleaner is being drawn into engine.
ICV worth a good clean every so often,but it sound more of a air leak to me .
STRAWB
« Reply #10 on: 02 April 2011, 13:45:00 »
Thank you Amba will do that and check the ICV  :) Fingers crossed then  :y
