Author Topic: help  (Read 876 times)
Zepp2
  • Bellshill
help
« on: 04 April 2011, 11:12:34 »
Hi all I have a 2.2 CD  the car with a spanner light came on the car seemed to run ok I tried the paper clip & pedal test now it wont start just clicks  put a battery pack on still wont turn over central locking not working as well any one any Ideas
Re: help
« Reply #1 on: 04 April 2011, 11:21:34 »
no connection between engine not turning over & the warning light - that's for emissions. You sure your battery pack is charged .......  :-?
How about jumping it from A N Other car with some decent jump leads  :-/
Zepp2
  • Bellshill
Re: help
« Reply #2 on: 04 April 2011, 11:35:46 »
Thanks will give it a try
Re: help
« Reply #3 on: 04 April 2011, 13:16:02 »
you can't paperclip test a 2.2, are you sure you've not accidentally blown fuse 15? If it started ok before, i suspect you might have blown a fuse.
Do all dash lights come on correctly when you turn the ignition on?
Zepp2
  • Bellshill
Re: help
« Reply #4 on: 04 April 2011, 14:15:01 »
Got It going with help of a breakdown company just put a booster pack on and it started no problem
