Author Topic: Head Gasket Failure  (Read 3043 times)
Re: Head Gasket Failure
« Reply #15 on: 04 April 2011, 14:46:14 »
Add to that a torque wrench or two and perhaps an angular gauge for head bolt tightening.
 <<Thicko question alert>>>
Having used the torque wrench to tighten to the specified figure, what is the purpose in then further tightening to a specified angle?
« Reply #16 on: 04 April 2011, 14:50:39 »
Some bolts stretch (by design), so an actual torque value is irrelavent.
heads are something like 30nm, then 90 degrees, then 90 degrees, then 90 degrees.
(and bloody hell, is that tight to do up!)
« Last Edit: 04 April 2011, 14:52:39 by jimbob »
« Reply #17 on: 04 April 2011, 15:40:50 »
Understood - thank you James. 8-) :y
« Reply #18 on: 04 April 2011, 16:50:14 »
Yep, the initial torque just gets it to a baseline where all the "slack" has been taken out. Angle tightening then theoretically adds a defined amount of "stretch".
