Author Topic: 2.2 auto gearbox ecu  (Read 1247 times)
vomega51
  • east london
« on: 04 April 2011, 19:01:22 »
hi, can anyone tell me where to find the gearbox ecu on an omega 2002 2.2  auto please, any help would be most appreciated, thanks
Re: 2.2 auto gearbox ecu
« Reply #1 on: 04 April 2011, 19:02:26 »
drivers kick panel iirc....
Why though? they dont normally need 'finding'
vomega51
  • east london
« Reply #2 on: 04 April 2011, 19:08:14 »
my gearbox seems to be a bit erratic, not as smooth as it used to be, it will hold on for what seems like ages before it changes from 2nd to 3rd and sounds like im thrashing it when i am not on kick down it just stays there for ages even when i release the throttle it still wont change up for about 40 secs
« Reply #3 on: 04 April 2011, 19:12:23 »
finding the ecu wont help, there will be nothing wrong with it.
(can possibly run a later software version, but it need to remain in the car to be updated)
Have you checked the gearbox fluid level?  or even better given it a full ATF change?
or had a code reader on the gearbox to see if any codes stored?  has it ever given you the automatic gearbox message on the display.
Does it ever really thump into gear?
vomega51
  • east london
« Reply #4 on: 04 April 2011, 19:42:24 »
hi jimbob, i will try changing the atf, it thumps into gear after holding on to the revs, have  had no messages in the display, will try a code reader tommorrow to see if anything comes up, thanks for your advice
« Reply #5 on: 04 April 2011, 19:59:30 »
Hi mate, have a look here and follow the guides  :y
http://www.omegaowners.com/forum/YaBB.pl?num=1152783586
http://www.omegaowners.com/forum/YaBB.pl?num=1289757627
http://www.omegaowners.com/forum/YaBB.pl?num=1267956397
« Reply #6 on: 04 April 2011, 20:44:19 »
The TCMs are supremely reliable, so that definately wouldn't be my first port of call.
Check the ATF, both for level and its condition.  And codes stored in the TCM (most code readers cannot read the TCM) might give some clues, but I suspect its a hydromechanical fault
jimac
  • Newcastle upon Tyne
    • Vectra 1.9 CDTi [150] SRi
« Reply #7 on: 05 April 2011, 10:49:47 »
Could be a failing cam sensor (code P0340).  Mine did this couple of times when I was getting the spanner or engine light on.  It's worth just disconnecting the cam sensor and reconnecting again.  This worked for me, but YMMV!
Page created in 0.031 seconds with 20 queries.
