Author Topic: injector removal help required.  (Read 1497 times)
sotmh
  • london
« on: 04 April 2011, 13:52:28 »
I've been able to remove connectors, but removing injectors are proving difficult, also inlet manifold support bracket.  Have removed one bolt but was wondering if there were others.  If there are I will need to jacyk up to gain access unless anyone knows different.  Assistance please
Re: injector removal help required.
« Reply #1 on: 04 April 2011, 15:19:50 »
Inlet manifold bracket bolts to the base of the engine block & needs to be undone from underneath the car. The Injectors are just a push fit on 'o' rings & should come out with the Injector rail afaik :-/
sotmh
  • london
« Reply #2 on: 04 April 2011, 15:59:05 »
thanks Phil. :y
sotmh
  • london
« Reply #3 on: 04 April 2011, 19:18:37 »
Unless I'm doing something realy unfathomably ridiculous I still can't remove injectors.
They are able to turn whilst still connected to injector assembly and within the exhaust manifold.
injector connectors are removed also the clips.  Am I doing something wrong :question
« Reply #4 on: 04 April 2011, 19:32:27 »
Hi sotmh, i've sent you a PM  :y
sotmh
  • london
« Reply #5 on: 05 April 2011, 13:03:46 »
PM SENT
