Author Topic: Rj6226 - are they the rear springs for me  (Read 1460 times)
markfree
« on: 01 April 2011, 22:37:09 »
Can someone please confirm that these are the correct rear springs (from Buypartsby) for my NON self levelling miggy  :y
Year 2000
« Last Edit: 01 April 2011, 22:42:06 by markfree »
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Rj6226 - are they the rear springs for me
« Reply #1 on: 02 April 2011, 08:49:35 »
i recently fitted rear springs to my 2003 V6 but these were RX 6226. My car is not self levelling
« Reply #2 on: 02 April 2011, 19:17:21 »
The kyb catalogue is viewable on line
But I have kyb sl springs here marked rj 6227.
Sure that's correct or I was supplied the wrong springs they are certainly soft.
amba
  • Medway towns
    • German V6
« Reply #3 on: 02 April 2011, 20:58:39 »
I ordered and fitted a pair of KYB.rj 6227 to my Elite Saloon as a direct replacement for my original springs which were for a self levelling set up.
They were a perfect fit and the exact same length to those removed.
markfree
« Reply #4 on: 02 April 2011, 22:34:46 »
I had alook at the KYB catalogue and was even more confused (it's not difficult really  ::)) but having read this :- http://www.omegaowners.com/forum/YaBB.pl?num=1243006966
and after looking at Marks dtm maintenance guide (which shows a RJ6226 spring) I decided to go with this spring - gave my reg to buypartsby so hopefully  ::) they will send me the right one.
Thanks for all replies  :y
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #5 on: 03 April 2011, 17:50:16 »
KYB catalogue is confusing I contacted KYB and they gave me the RX6226 as being right for my car.
markfree
« Reply #6 on: 05 April 2011, 14:31:08 »
Buypartsby have sent me a RX5413 spring after I ordered RJ6226 springs but having said that it does look the correct spring - note spring (singular) - they also sent me a front spring 504142 >:(
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
« Reply #7 on: 05 April 2011, 15:06:31 »
I would suggest a call to KYB but that said when I asked them if the spring had a top and bottom they said " I dont think that it matters"    Think?
amba
  • Medway towns
    • German V6
« Reply #8 on: 05 April 2011, 15:24:46 »
Springs I ordered only had a part number and no arrow for direction.
Sort further advise off forum and it appeared that it didn,t matter which way they were fitted,as long as you ensure the "pigtail"at the top is facing the rear of the car.
Also ensure that the top is located onto the groove within the rubber cushion pad.Well that is how I fitted mine and have had no issues since..and now covered about 3k
