Author Topic: Tow bar advice  (Read 3285 times)
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
Tow bar advice
« on: 05 April 2011, 21:50:05 »
I,m thinking of getting a tow bar and fitting it myself, is this an easy job and are the electrics already in place, I'm sure i've noticed a small connector near to the o/s rear light cluster.
It's on a 98 2.5 CD.
Jon
Jon
dad1uk
  • Birmingham
    • Vauxhall Zafira 2.2
Re: Tow bar advice
« Reply #1 on: 05 April 2011, 22:00:00 »
http://www.omegaowners.com/forum/YaBB.pl?num=1242490914/0
http://www.omegaowners.com/forum/YaBB.pl?num=1171117165/0
http://www.witter-towbars.co.uk/uMedia/FittingInstructions/G67A.pdf
It's easy, the bolt holes are marked with dimples
You just need to drill them out.
The easiest way for the wiring is to get the kit from Vx and this plugs straight into the plug in the boot.
best wishes
Simon.
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
Re: Tow bar advice
« Reply #2 on: 05 April 2011, 22:13:59 »
Thanks for that Dad  :y, any recommendations on which tow bars are best, its only for pulling a trailer.
Jon
Agemo
  • Cleethorpes
  • Insignia
Re: Tow bar advice
« Reply #3 on: 05 April 2011, 22:19:18 »
You will probably find a breaker on here has one, the chances are though, the wiring will have been chopped, so you will have to trace them all.
Re: Tow bar advice
« Reply #4 on: 05 April 2011, 22:36:15 »
Depends on what you want it too look like. IMO the Witter two bolt flange box section tow bar looks shite could look better, loads of 2" box section showing from underneath versus a Bosal OE supplied bar which has all the rigidity inside the boot floor with just the swan neck 'dangling' from the unseen metalwork above it. Or a Westfalia detachable with swing away electrics - like mine.  ;) :y
BlueBridge
  • Wirral
    • 3.0 Elite Saloon
Re: Tow bar advice
« Reply #5 on: 05 April 2011, 23:19:17 »
Cheers Andy :y
I'll avoid the Witter.
Jon
YZ250
  • Oxford/Bucks border
    • Black 3.2 Elite Estate
Re: Tow bar advice
« Reply #6 on: 05 April 2011, 23:55:48 »
Unfortunately, I have to use the additional parking sensor two bolt flange towbar as I tow a caravan with a dry ball for the Alko AKS Hitch Head but also tow a Moto X bike trailer with the pressed steel greased head. It's easier for me to just change the towball over which allows me to tow any trailer. Mine's fitted to an Estate so the only iron work showing is the parts that drop down from behind the bumper to the two bolt flange although I do agree it's not cosmetically great and detachable is the prettier option.  :y
« Last Edit: 06 April 2011, 00:13:54 by Alan-Hearn »
Re: Tow bar advice
« Reply #7 on: 06 April 2011, 06:40:47 »
It's easier for me to just change the towball over which allows me to tow any trailer.  ....
It's easier to undo 2 x M16 bolts than it is to use a rag & thinners?  :-?
robson
  • Nr Ashford Kent
    • 2.6 facelift 2003
Re: Tow bar advice
« Reply #8 on: 06 April 2011, 21:59:43 »
I agree with Andy I tow both an old trailer and a caravan with Alko .A quick degrease is all thats needed
Re: Tow bar advice
« Reply #9 on: 06 April 2011, 22:04:54 »
Some thinners contain a light "lubricant" type stuff that leaves a film on the towball... this can damage the friction pads in the hitch .. if you have an alko or westfalia ... better to use a quick spray of brake/clutch cleaner and a bit of paper towel IMHO ... leaves no residue at all ..  :)
YZ250
Re: Tow bar advice
« Reply #10 on: 06 April 2011, 22:10:29 »
I originally towed with a swan neck towbar but my straightliner stabiliser was no good on it. The clamp kept turning on the neck so I was forced to change it to a flange ball. Came in useful for a bike carrier as well. Obviously now I don't use the straightliner so I could use any style towbar. The OP only needs to tow a trailer but may want to stick a bike on at a later date. Personal choice for current requirements at the end of the day.  :y
Re: Tow bar advice
« Reply #11 on: 06 April 2011, 22:10:59 »
you're splitting hairs now Nige.  ;) ;) ;)
You knew what I meant, ;)
Just for you ........
It's easier to undo 2 x M16 bolts than it is to use a rag & thinners brake cleaner?
actually I'd use Domino printer wash from work ....... acetone.  ;) ;) ;)
Re: Tow bar advice
« Reply #12 on: 06 April 2011, 22:13:40 »
methinks your              is a tad too long .......  :)
and that IS splitting hairs .... :)
Re: Tow bar advice
« Reply #13 on: 06 April 2011, 22:14:07 »
True!
But a 2 bolt flanged towball looks ugly which ever way you look at it. It was only 'cos this caravan came with an Al-ko that  I use a stabiliser. I towed the last caravan miles - here & abroad - without a stabiliser of any kind.
Re: Tow bar advice
« Reply #14 on: 06 April 2011, 22:15:05 »
It is !!!!!!!!!!!!  ;D ;D ;D ;D ;D  :y
