Author Topic: Removing seat Help  (Read 1238 times)
davethediver
  • Blackburn, Lancs.
Removing seat Help
« on: 07 April 2011, 18:46:46 »
Hi guys i am in the process of changing my passenger seat, have got bolts out and battery been disconected for half hour>
How the hell do you seperate the electrical connections?
Please help it will be dark soon :y
P.A. Caron de Beaumarchais
SJKOO01
Re: Removing seat Help
« Reply #1 on: 07 April 2011, 18:55:16 »
Yellow and grey plugs have an orange or yellow securing tab/strip which you need to pull (slide) out then they have a locking tab that you have to lift carefully then they should separate.
The big black one, again has an orange or yellow securing tab/strip, as above slide it out. then there is a big push type button part in the middle on one side which you push, then pull both parts away from each other.
Best way I could describe it quickly in written format to you, hope it helps to  :y
davethediver
  • Blackburn, Lancs.
« Reply #2 on: 07 April 2011, 20:15:02 »
Thanks Goose all sorted now, figued it out just before i saw your reply :y
Biggest problem was taking out the torx bolts that some t%&* had rounded and putting it all back together. Noce full sports leather set in it now :y
SJKOO01
« Reply #3 on: 07 April 2011, 20:21:07 »
Glad you got it sorted  :y
