Author Topic: Temperature  (Read 1598 times)
Mick2.6
Temperature
« on: 08 April 2011, 16:17:01 »
My Omega 2.6 cdx is currently running at 92 degrees. Is this the correct temperture is should be, or is this running to hot?
Does the cooling system need attention?
davethediver
  • Blackburn, Lancs.
Re: Temperature
« Reply #1 on: 08 April 2011, 16:27:29 »
Don't think its too far out needle should be halfway on the guage :)
Have a look here http://www.omegaowners.com/forum/YaBB.pl?num=1265649820
HTH :y
« Last Edit: 08 April 2011, 16:29:14 by davethediver »
P.A. Caron de Beaumarchais
Mick2.6
Re: Temperature
« Reply #2 on: 08 April 2011, 16:45:47 »
Thanks for the help, so is the car running at the correct temperature?
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
Re: Temperature
« Reply #3 on: 08 April 2011, 16:47:06 »
Mine was up and down that's why i put a new thermostat in yesterday, now the temp is fine around mid of gauge about 90deg. But yours sounds fine
tigers_gonads
  • Kinston Upon Hull
  • Sill breathing
    • Audi A6 Allroad BiTd
Re: Temperature
« Reply #4 on: 08 April 2011, 17:20:23 »
I think thats about right for a V6  :y
Does the fan kick in ok ?
dazzerM
  • Reading
  • Mokka 1.7CDTI, BMW 120D Shadow (It’s a work car)
    • Which ones closest
Re: Temperature
« Reply #5 on: 08 April 2011, 20:18:20 »
I got my MV6 this week and I was straight on here 3 days later worrying that it was running far too hot and it was about to explode :D Around 85 on a run and 90-92 in traffic then the fan kicked in and put it back in to the 80s.
I was reassured by so many members that this was normal -  8-)
Darren
Miggylover
Re: Temperature
« Reply #6 on: 09 April 2011, 11:43:29 »
That's pretty normal. As long as the fan still kicks in etc then you will be fine. On my old corsa the fan didnt even kick in until 100 degrees.
