Author Topic: Time for an Auto box service possibly??  (Read 1022 times)
Crazycarzowner
« on: 09 April 2011, 22:08:17 »
I think I know the answer to this before I ask but I'd value you guys opinions.
My 2.6 auto is how do I put it gettin a bit lazy in changing up through the gears. 1st to 2nd ok, 2nd to 3rd is like errrrrrrrrmmmmmmm go on then......(hangs for a little bit).......yep then changes up. Sometimes when normal everyday driving 2nd to 3rd will only happen if I accelerate over 3500rpm, other days its as smooth as. 3rd to 4th can sometimes be the same too, its like being in sports mode sometimes. I notice it more from a cold start, have looked underneath but can't see any leaks. I do live on a slight incline but I don't think that would affect matters??? At 52k on a 2002 plate.
I'm goin down the lines of either low ATF possibly or time for a g/box service - new filter & new ATF????
« Last Edit: 09 April 2011, 22:14:26 by Crazycarzowner »
twiglet
  • Norwich, Norfolk
Re: Time for an Auto box service possibly??
« Reply #1 on: 09 April 2011, 22:23:56 »
I assume you're not getting any fault codes?
Certainly a filter and ATF change is a good starting point in solving gearbox issues!  :y
Crazycarzowner
« Reply #2 on: 09 April 2011, 22:26:54 »
No, no fault codes as of yet, gonna start with a filter & new ATF I think.
« Reply #3 on: 09 April 2011, 22:30:08 »
You can only change about 1/2 the ATF by dropping both sumps .. the rest is inaccessible .. :( but even that makes a difference  :)
« Reply #4 on: 09 April 2011, 23:05:25 »
2nd to 3rd solenoid is often mentioned on here, might be with swapping that solenoid for a new one while the sumps are off?
Malcolm_D
  • York
  • It shines!
« Reply #5 on: 10 April 2011, 08:47:36 »
Can you remove more than half if you use a Pela suction oil extractor pump?  :-/
« Reply #6 on: 10 April 2011, 09:53:27 »
Nope .. the remaining ATF is inside the internal workings, the Torque Converter and the cooler pipes.
