Pages: [1] 2 3  All   Go Down
Author Topic: LPG Liquid feed valve  (Read 3465 times)
« on: 11 April 2011, 10:44:22 »
Does anyone know what the sealing method should be on these?
Does it rely on a taper at the bottom (whould have to be precise manufacture, as valve has to point in a precise direction), or should there be some kind of sealing compound on the thread?
Re: LPG Liquid feed valve
« Reply #1 on: 11 April 2011, 10:47:02 »
Do you mean the outlet on the 4 hole tank?
I believe it's sealed by the compound, rather than position.
I had to rotate mine clockwise, to clear a bracket inside the airtight box. It was 'Effin tight and hard to move!!
« Reply #2 on: 11 April 2011, 10:48:28 »
Also, if you have a 4 hole - the valves should be pre - fitted, so providing they point in suitable directions, you can leave them as-is. :)
« Reply #3 on: 11 April 2011, 11:03:55 »
It would appear not always ;)
« Reply #4 on: 11 April 2011, 11:20:44 »
I'd give your tank supplier a slap  ;D
« Reply #5 on: 11 April 2011, 11:38:19 »
mine was not pre-fitted either, it was just based on the thread.
« Reply #6 on: 11 April 2011, 11:43:46 »
Yours is a multivalve, so generally these don't come pre-fitted
Never known 4 hole tanks coming without valves before, though!
« Reply #7 on: 11 April 2011, 11:43:48 »
Yours is multivalve, very different, uses a rubber seal iirc
« Last Edit: 11 April 2011, 11:44:50 by TheBoy »
« Reply #8 on: 11 April 2011, 11:52:21 »
Well thats your fault for buying a stupid tank with more holes  ;D
« Reply #9 on: 11 April 2011, 11:54:44 »
Power is for gentlemen of a certain age. 4 pots are for useless students. Learn and get over it ;)
« Reply #10 on: 11 April 2011, 12:29:11 »
I would imagine the fitting has a tapered thread rather than seat, allowing it to seal with a little adjustability in the angle.
The question is: what "compound" is used to seal them?
Gut feeling is that PTFE gas tape might do the job, but mine looks to have been sealed with a paste of some sort. Given the PITA involved in resealing, it needs to be done the "correct" way.
« Reply #11 on: 11 April 2011, 12:32:14 »
I would have thought liquid PTFE would be the way to go
« Reply #12 on: 11 April 2011, 12:55:37 »
Got a name and where I can get it? ie, something B&Q or Wickes, given the lack of anything useful around here.
Does it have to be gas specific - ie, not normal plumbers stuff?
« Reply #13 on: 11 April 2011, 13:09:09 »
This:
http://www.screwfix.com/p/ptfe-gas-tape-pack-of-10/53966
combined with this
http://www.screwfix.com/p/no-nonsense-ptfe-liquid/40302
So remove valve (could be easier said that done!), clean up thread of threadlock, wrap in PTFE tape, add some PTFE liquid "to make sure", screw back in?
« Reply #14 on: 11 April 2011, 13:11:43 »
or
http://www.screwfix.com/p/liquid-ptfe-50g/30469
given that the reviews on the No-Nonsesne liquid I posted earlier imply its shite! And this one mentions LPG
« Last Edit: 11 April 2011, 13:12:09 by TheBoy »
Pages: [1] 2 3  All   Go Up
Page created in 0.009 seconds with 14 queries.
