Author Topic: Power Steering Fluid  (Read 1256 times)
mikeh
  • London
    • 1999 V6 2.5 petrol MFL
« on: 11 April 2011, 16:48:09 »
Hi, Can someone please tell me what type/brand/spec of power steering fluid the omega uses? Its a 1999 V6 2.5 petrol model.
Thanks,
Mike.
Re: Power Steering Fluid
« Reply #1 on: 11 April 2011, 17:09:34 »
Dex II Automatic transmission fluid. :y
mikeh
  • London
« Reply #2 on: 11 April 2011, 17:11:05 »
Thanks Kevin.
mikeh
  • London
« Reply #3 on: 12 April 2011, 10:49:49 »
Local Vauxhall dealer (Phoenix) are saying they only use one fluid now which is Dex VI. Is this ok to use? If not, where do you get your Dex II from?
Thanks,
Mike.
« Reply #4 on: 12 April 2011, 11:09:22 »
Any motor factors should have Dex II ATF
« Reply #5 on: 12 April 2011, 11:28:32 »
Thanks,
Mike.
Considering DEX III was the spec, but was downgraded cos of problems and leaks caused.  I would not use anything but dex II
« Reply #6 on: 12 April 2011, 11:32:28 »
Dealers will happily sell you what they have regardless, and at ott prices.
Dex2 from anywhere except dealers. :y
andyc
  • Norfolk
« Reply #7 on: 12 April 2011, 14:47:29 »
It seems GM have superseeded DEX2 & 3 to Dex 6 but as said any good factor will be able to supply DEX2.
Andy
Thetford. Norfolk
« Reply #8 on: 12 April 2011, 14:53:01 »
Andy
Gm have forgotten there own service info it seems...?    :-/
« Last Edit: 12 April 2011, 14:53:25 by chrisgixer »
« Reply #9 on: 12 April 2011, 14:57:40 »
Andy
well technically....dex 3 caused an issue....dex 6 MAY be fine....but £1 to 1p they havent tested it in an omega to know if it will cause a leak or not.  and given the age they prob wont get any complaints
