Author Topic: Wife stranded & I need my dinner  (Read 1674 times)
KJO
  • Cork
« on: 31 March 2011, 18:13:33 »
Its an auto box, see previous posts. Starter will not engage, will not come out of park. However there is battery power. I thought I saw something under general topics about the switch in the box jamming & having to remove the cover inside the car & manually operating a switch but can't find it. I think that this is causing the problem. The box has been running in limp mode for 3 mths. Help would be appreciated as I am getting hungry (I jest) but I don't think the Wife will be not too happy if she has to walk home 8 miles. :(
Re: Wife stranded & I need my dinner
« Reply #1 on: 31 March 2011, 18:25:54 »
Lift the gearlever surround up & release with the yellow lever
« Reply #2 on: 31 March 2011, 18:50:54 »
But if it's not starting that isn't the fault... Could be that the selector switch has completely given up or just confused :-?
Tell her to try turning the ignition on, foot on brake and move lever from P to 1 and back again a few times, if needs be using the method pictured above, and to try starting it in N as well :y
KJO
  • Cork
« Reply #3 on: 31 March 2011, 18:54:02 »
In case the roadside assist boys don't know how to lift the cover do you have any instructions. I'm very grateful for you getting back to me so quickly. :y
« Reply #4 on: 31 March 2011, 19:06:02 »
The cover is easy... Just give it a gentle pry ;)
I would suggest changing Roadside Assist company if they don't know it though :o ::)
SJKOO01
« Reply #5 on: 31 March 2011, 19:10:00 »
Where the leather gater is around shifter, pull up on the rear part where the plastic part is clipped in (towards handbrake) and it should just give enough room then.
KJO
  • Cork
« Reply #6 on: 31 March 2011, 19:26:24 »
Many thanks for your reply. The car will start in neutral but not in park :-?
« Reply #7 on: 31 March 2011, 20:40:48 »
I think the start inhibitor is part of the selector switch ::) ::)
Be the last time I suggest it... Before you condemn the gearbox, clean the selector switch ;)
« Reply #8 on: 31 March 2011, 20:42:54 »
.......another sympton of a dodgy selector switch.
« Last Edit: 31 March 2011, 20:43:57 by RobG »
« Reply #9 on: 31 March 2011, 20:45:54 »
Seems like wasted advice
« Reply #10 on: 31 March 2011, 21:04:35 »
To be fair, I missed the original post until yesterday/today... But it has been suggested a few times now ::)
« Reply #11 on: 31 March 2011, 21:53:19 »
Like others, I will not mention the selector switch again.
Your choice if you wish to take the advice offered.
Excessive use of the gearbox when its in limp, due to said knackered selector switch, you will mechanically shag the box.
KJO
  • Cork
« Reply #12 on: 14 April 2011, 10:15:39 »
The selector switch was taken off to be cleaned but found to be beyond use. Replacement selector switch fitted but gear box not working properly. Shuddering badly when starting off in drive. Probably knackered the box driving approx 7k miles in limp mode but no alternative at the time. Sourced a replacement box for 250 and the car is running beatifuly and doing 5 mpg better fuel consumption. :y
