Author Topic: Bank 2 Sensor 1  (Read 1381 times)
Bank 2 Sensor 1
« on: 15 April 2011, 19:06:05 »
Which Lambda is it and are they the same as a 3.0 one?
TIA :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
Re: Bank 2 Sensor 1
« Reply #1 on: 15 April 2011, 19:29:28 »
Bank 2 is passenger side and the o2 sensors are a different length. .  Well the ones I have fitted  :y
That said they are positioned in different places on the gearbox. .  Many need to check their lengths tomorrow now   :-?
« Last Edit: 15 April 2011, 19:33:46 by Loo-knee »
Darth Loo-knee
  • Death Star
    • TIE Fighter
Re: Bank 2 Sensor 1
« Reply #2 on: 15 April 2011, 19:34:58 »
These Black Russians taste lovely but they are taking hold. . Sorry youth  :D
Re: Bank 2 Sensor 1
« Reply #3 on: 15 April 2011, 22:51:44 »
Cheers Youth, if the plugs the same i'll extend the wiring :y
Re: Bank 2 Sensor 1
« Reply #4 on: 15 April 2011, 23:12:01 »
DBW cars have 4 wire sensors and, IIRC, Non-DBW are 3 wire.
Passenger side, as said, and sensor 1 is the pre-cat sensor.
Re: Bank 2 Sensor 1
« Reply #5 on: 15 April 2011, 23:21:26 »
Thanks Kevin :y
Re: Bank 2 Sensor 1
« Reply #6 on: 15 April 2011, 23:26:12 »
I've got a 0150 code so i'll check the wiring first. I thought the Lambdas were fairly reliable.
Re: Bank 2 Sensor 1
« Reply #7 on: 16 April 2011, 01:07:16 »
Yep, normally not a problem, except for AutoAddict's. ;)
Could be that the lambda sensor is seeing a rich/lean mixture due to another fault which is causing a lack of activity. If they'll come out easily, swap the Lambda sensor to the other bank and see if the fault follows it. :y
Re: Bank 2 Sensor 1
« Reply #8 on: 16 April 2011, 07:09:44 »
I'll have a crack at it tomorrow :y
Auto Addict
  • North Birmingham
  • Back to Vx to keep TB happy
    • Astra K Elite ST
Re: Bank 2 Sensor 1
« Reply #9 on: 16 April 2011, 09:06:50 »
I bought a Bosch one from these:-
http://stores.ebay.co.uk/POWERSPARKS
Free delivery - and it worked :y
Cheaper than Vx.
I like red cars
Re: Bank 2 Sensor 1
« Reply #10 on: 16 April 2011, 09:43:33 »
Cheaper than Vx.
Has that cured your problem then, pikey?
