Author Topic: Advice  (Read 1762 times)
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Advice
« on: 16 April 2011, 19:37:10 »
Still getting codes, P0743,P0753 and P1700. Should I take the chance and put her into the specialist and I know for a fact I will get ripped off. As they wanted £250 to replace solonoid and I did It for half the price. As I said it did not clear codes. or should I try and pick up a refurbished auto box and try and fit it myself but then again might be electrical and code will still not clear. Any advice appreciated.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice
« Reply #1 on: 16 April 2011, 20:31:24 »
Now all the lights are lit on the gearbox ?????
doug4293
  • greenock, scotland
Re: Advice
« Reply #2 on: 16 April 2011, 20:43:04 »
suggests to me , selector switch on gearbox, when u put it on drive does it go into limp mode , ie sticks in 3rd gear (like normally putting in drive and trying to pull off with snow button on ? )
Signature deleted as it's too big.
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice
« Reply #3 on: 16 April 2011, 20:48:48 »
Has been in limp mode for weeks because of codes mentioned earlier in the thread
Re: Advice
« Reply #4 on: 16 April 2011, 21:49:37 »
Thats a selector switch fault
Re: Advice
« Reply #5 on: 16 April 2011, 21:54:37 »
What device are you using to read these codes?
Re: Advice
« Reply #6 on: 16 April 2011, 22:05:42 »
kind of .......  :-/
The original gear box tell tale on my car used to be fine when the main lights were OFF, but as soon as I turned them on, all the selector tell tale leds lit. A 'new' tell tale fixed it.
Re: Advice
« Reply #7 on: 16 April 2011, 22:13:14 »
kind of .......  :-/
That would be another unrelated fault on this box... ...a shade too coincidental, even for me
Re: Advice
« Reply #8 on: 16 April 2011, 22:19:52 »
kind of .......  :-/
I was just trying to be awkward .......... apparently SWMBO says I'm not bad good at that.  ::)   ;)
Abiton
Re: Advice
« Reply #9 on: 16 April 2011, 22:24:31 »
Not much left in the bottle, so excuse me if this is nonsense, but haven't I read on here that dodgy cam sensor can throw autobox codes on 2.2s?  Can't remember whether it's been known to fail without showing its own fault code.
Has the cam sensor ever been changed? (If so, with genuine Vx part?).
If not, it may be worth borrowing a known good one from a local 2.2-er to see what happens.  :-/
Raymienets
  • Glasgow
    • 2.2 cd & 2.6 LPG
Re: Advice
« Reply #10 on: 17 April 2011, 00:09:06 »
Was changed about 6 month ago with genuine Vaux part
ffcgary1
  • Mitcham,Surrey.
    • Omega Estate/ jaguar XJ6
Re: Advice
« Reply #11 on: 17 April 2011, 00:14:23 »
I would change the selector switch first, its a damm sight cheaper than an auto box then if that still does not sort the problem then source a decent second hand box from one of the breakers on here and go from there.
Jaguar XJ6
