Author Topic: Cam Belt Change  (Read 1947 times)
Andy2009
  • Norwich
Cam Belt Change
« on: 16 April 2011, 19:02:51 »
Hi
Can anyone tell me at what milage the Cam Belt should be changed on an Omega 2.2 petrol (2002)?
Re: Cam Belt Change
« Reply #1 on: 16 April 2011, 19:08:35 »
40,000 miles or 4 years on all petrol Omega's.
Without fail.
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
Re: Cam Belt Change
« Reply #2 on: 17 April 2011, 09:52:28 »
As Entwood says, plus always a full kit AND the water pump :y
other rides
Re: Cam Belt Change
« Reply #3 on: 17 April 2011, 16:54:15 »
..... AND the water pump :y
Changing the water pump is peculiar to this sight as respect to a V6 and isn't really neccessary ( I know the reasons but don't agree) and concidering the price of an OE pump, even on TC would make me even more inclined to not fix what's not broke. Which is better, a cheap(er) generic pump or a used OE pump ................. there's only one way to find out  ;D  ;D  ;D  ;D
henryd
  • west cornwall
Re: Cam Belt Change
« Reply #4 on: 18 April 2011, 12:31:17 »
Andy, the OP is asking about a 2.2 on which the water pump is cam belt driven so should be replaced with the belt kit :y
other rides
blackviper90210
  • Bromsgrove, West Midlands
    • 03 3.2 Elite Saloon
Re: Cam Belt Change
« Reply #5 on: 18 April 2011, 21:23:58 »
Does the water pump need to be changed on the V6 with a cambelt change then, or is that optional/recommended or deff do it?
Cheers  :y
AKA - Mr Bracket
Re: Cam Belt Change
« Reply #6 on: 18 April 2011, 21:27:03 »
For the sake of £35 I would replace it every time but I think Vauxhall do it every other cambelt change ;)
Re: Cam Belt Change
« Reply #7 on: 18 April 2011, 21:30:08 »
Cheers  :y
My apologies .......... I've not read the post properly again  ::) ::) ::)
It's good policy on 4 cylinder cars to have the water pump changed with the cam belt.
If you're paying someone to do the cam belt ie you can't/won't do it yourself, then change the water pump. If you're doing it yourself & don't mind covering old ground by accessing the water pump again, then I wouldn't replace the pump as a matter of course.
AIMHO  ;) ;)
Re: Cam Belt Change
« Reply #8 on: 18 April 2011, 21:31:35 »
but I'm sure a Vauxhall water pump isn't £35 any more  :-/ :-/ :-/
blackviper90210
Re: Cam Belt Change
« Reply #9 on: 18 April 2011, 21:36:01 »
Thanks guys, will check my local stealers for a price check!  :y
AKA - Mr Bracket
Re: Cam Belt Change
« Reply #10 on: 18 April 2011, 21:55:42 »
Its £70+ now but a good pattern part is about £35 ;)
Re: Cam Belt Change
« Reply #11 on: 18 April 2011, 22:01:01 »
On a v6 - I agree. Dont see the point of taking off a perfectly good VX pump and putting a pattern one on, just in case the VX one wears out at some point in the future.It was probably a good idea when genuine pumps were cheap as chips, but as you say, they arent cheap anymore. :y
Re: Cam Belt Change
« Reply #12 on: 18 April 2011, 22:06:03 »
I'll stick with a part used OE pump rather than swap it for a pattern pump.  ;) ;)
« Last Edit: 18 April 2011, 22:15:31 by Andy_B »
Re: Cam Belt Change
« Reply #13 on: 18 April 2011, 22:13:01 »
I'll still with a part used OE pump rather than swap it for a pattern pump.  ;) ;)
I've only ever had one fail after about 4 months (and i've replaced a fair few) and it was promptly exchanged :y
Re: Cam Belt Change
« Reply #14 on: 18 April 2011, 22:18:10 »
I'll stick (I seem to be typing sh1te tonight  ::)) with a part used OE pump rather than swap it for a pattern pump.  ;) ;)
As said, it depends if you're paying someone else. I'll stick with 'if it ain't broke, don't fix it'  ;) ;) ;)
Page created in 0.024 seconds with 16 queries.
