Author Topic: Dual Mass Flywheel  (Read 3698 times)
    • 530D M Sport, 330i Coupe
Dual Mass Flywheel
« on: 19 April 2011, 18:50:45 »
Just a general query really, what are the symptoms of one of these units failing? If, when the time comes, I need to replace the clutch on my DTi I would hate to find on parting the engine and gearbox that the DMF also is failing.....
Omegatoy
  • UK
Re: Dual Mass Flywheel
« Reply #1 on: 19 April 2011, 18:57:53 »
noise that sounds like a thrust bearing, vibration at certain points of the rev range, or shunt from the driveline take up i.e when pulling away or changing gear are the most common failures,
when you get the clutch out you can move the two halves against each other(rotate)and check the amount of movement that is in there and whether or not its a smooth movement
edit forgot!! sometimes you get a "clonk" when using the starter motor!!
« Last Edit: 19 April 2011, 19:01:36 by Omegatoy »
« Reply #2 on: 19 April 2011, 19:07:00 »
That sounds reassuring for both the DTi's then as neither has those symptoms!
Incidently, the bite point on the Estate's clutch is much more defined after burning it a little bit reversing up a field with the caravan attached on wet grass up a slope.  ::) ;D
Omegatoy
  • UK
« Reply #3 on: 19 April 2011, 19:10:20 »
Hmm wet grass >:( slipperiest substance known to road tyres!!mud and snow tyres on the back would be easier!!! ;D ;D
« Reply #4 on: 19 April 2011, 19:15:57 »
what are the supposed advantages of a dual mass flywheel over the old style sprung clutch plate, DMFs seem to fail no matter what make of car they're fitted to.
I won't mention auto vs manual in this question  ::) ::) ::) ::)
« Reply #5 on: 19 April 2011, 19:17:42 »
The smell of burning clutch lingers for a little while!  ;D
Jane was busy telling me that she hoped I hadn't ruined THE clutch.... then I reminded her that it's HER clutch, mine is on the driveway in Solihull....  ;D
Omegatoy
  • UK
« Reply #6 on: 19 April 2011, 21:24:16 »
"supposedly" smoother drivetrain i.e less vibration and easier clutch takeup it also balances engine vibration that they couldnt be bothered to cure on manufacture ::) gives the whole drivetrain, g.box rop and rear axle a smaller shock loading, supposedly!!!!! :y
Mrs VXL V6
    • 2.2 DTI Estate
« Reply #7 on: 19 April 2011, 22:01:33 »
Yes indeed what a smell, you need laugh about it!  I will have to get my own back at some point!!  Mr VXL V6 why do you keep the key for the 3.2 hidden?
« Reply #8 on: 19 April 2011, 22:09:17 »
Errr ummm,
Hello my love..
It's not hidden... there's just no point leaving it handy 'cause the temptation is too great..... You are welcome to use it - currently needs 70L of V Power in it though....  ;D
Mrs VXL V6
    • 2.2 DTI Estate
« Reply #9 on: 19 April 2011, 22:13:47 »
Errr ummm,
Hello my love..
No problem I'll put fuel in it if I know where the key is, but their is a problem the 3.2 does not have a clutch!! :o
« Reply #10 on: 19 April 2011, 22:20:12 »
..... but there is a problem the 3.2 does not have a clutch!! :o
How can no clutch be a problem?  :-? :-? :-?
2 pedals is the future ;) ;) :y :y :y :y
« Reply #11 on: 19 April 2011, 22:26:28 »
No need for that ancient Cog technology with a 'proper' engine under the bonnet ;D
« Reply #12 on: 19 April 2011, 22:30:33 »
 ;D ;D ;D ;D
Mrs VXL V6
    • 2.2 DTI Estate
« Reply #13 on: 19 April 2011, 22:30:49 »
Yes auto is best but I can't get my own back by burning the clutch on his best car the 3.2 as it does not have one!  oh well I will have to jump into his DTi  ;D But then again to stay Mrs VXL V6 I better think again.  What am I cooking tomorrow night.....
« Reply #14 on: 19 April 2011, 22:37:20 »
DMF's on Omegas are pretty bullet proof TBH.
The best indicator is a clonk on startup......
