Author Topic: What is the correct size of tyre for 17" wheels ?  (Read 4314 times)
Hannah Judes Dad
    • the misses round the bend
« on: 18 April 2011, 20:06:52 »
As per the header,I'm looking at a set of 17" wheels on egay at the moment that were on a Vectra the present size is 215 50 17.Will these be ok to use as is or will they need new rubber? Thanks in advance folks  :y
Re: What is the correct size of tyre for 17" wheels ?
« Reply #1 on: 18 April 2011, 20:15:25 »
235 45 17  ;) ;) No idea of the comparable rolling radius though  :-/
Hannah Judes Dad
« Reply #2 on: 18 April 2011, 20:37:16 »
Judging by the size difference it will show that my car is going faster than it really is but I wonder by how much ?
I hope someone on here can work it out,I'm too thick  :-[
henryd
  • west cornwall
  • VW Touareg R5 tdi Auto
« Reply #3 on: 18 April 2011, 20:57:32 »
The two sizes mentioned have about 0.5km/h difference in them so negligible,sorry it's km/h but that was the site I used :y
other rides
« Reply #4 on: 18 April 2011, 21:23:23 »
You may have an insurance issue as well so I would let then know you've changed the tyre size ;)
hotel21
  • The Kingdom of Fife
Hannah Judes Dad
« Reply #6 on: 18 April 2011, 21:36:53 »
No problem it equates to less than 0.32 mph so it's nothing to worry about  :y
twiglet
  • Norwich, Norfolk
« Reply #7 on: 18 April 2011, 22:56:38 »
What about the offset? I thought Omega's had a different offset to the FWD vxl's. Not sure if this would be an issue though...
Terbs
  • Brackley/Wareham
  • The Freezer Geezer
    • CD Saloon 2003
« Reply #8 on: 19 April 2011, 11:02:41 »
I bought my Omega with 17" alloys fitted. Are they not the ones it started life with? Had the geometry all checked out at WIM a while back, and nothing was said about the wheels not being 'normal'. My tyres are 235/45/17  :y
As Pete mentions insurance....do I need to contact them. I am sure handbook lists my tyres, will have to dig it out. :(
« Reply #9 on: 19 April 2011, 11:05:20 »
your car is a facelift  ;) so were standard.
Are they not the ones it started life with?  .....
No. His car came with 16" cos it's prefacelift.  :y
« Last Edit: 19 April 2011, 11:06:24 by Andy_B »
Terbs
  • Brackley/Wareham
    • CD Saloon 2003
« Reply #10 on: 19 April 2011, 11:08:56 »
Thanks Andy :y
hotel21
« Reply #11 on: 19 April 2011, 11:10:30 »
Elites generally had alloys as standard however, over several years/owners, may have steels fitted - or vice versa, if it started with steels.
Have a look through the gallery section and see the range of standard alloys.  The ones on mine are factory standard and 235/45-17.
duggs
  • Felixstowe
    • BMW 3.0 Sport
« Reply #12 on: 19 April 2011, 13:29:04 »
I have 235's on my Elite along with Vectra C wheels. See "Sunny Suffolk Day" in the gallery section.
Malcolm_D
  • York
  • It shines!
« Reply #13 on: 19 April 2011, 17:41:01 »
Totally off thread but is there a guide to include pictures of this size in a forum message?  :-[
Mr Gav
  • Leeds
    • Nissan 370z GT Edition
« Reply #14 on: 19 April 2011, 18:02:23 »
I think it`s a potential issue, Omegas use a 33mm offset where as the Vectra uses something like a 40mm offset. This means your wheels will be sat 7mm further in than standard.
The wheels on my omega are 7x17 and have a 40mm offset and they just don`t look right, also both front wheel bearings have failed recently and looking through the service history I`ve found that they done in 2007 and I`m convinced that the premature failure on both at the same time is caused by the wheels using the wrong offset.
As for the correct size for a 17" wheel, it depends on the width, a 235 would be too wide for a 7" rim but fine for a 8" rim.
