Author Topic: Vibration from Engine  (Read 1020 times)
TR
« on: 22 April 2011, 12:23:36 »
Looking for help or advice to solve a problem re vibration from engine on a 2000 Estate 2.5 CD. When I take my foot off accelerator there is a vibrating noise from engine. Anyone got any ideas?
Bent valve
Re: Vibration from Engine
« Reply #1 on: 22 April 2011, 21:42:06 »
Does it vibrate in neutral when you rev it then lift off the throttle? check the auxillarly belt tensioner to make sure the belt is not slack. also check the water pump, power steering and aircon compressor pulleys for play.
 It could also be that the front pulley which is also a harmonic damper is on the way out.
SMD
  • London
    • :( nowt
« Reply #2 on: 22 April 2011, 23:16:31 »
I had a similar problem but the vibration was coming from the rear. Topped up the ATF which sorted it.
TR
« Reply #3 on: 23 April 2011, 11:49:09 »
Many thanks for both bits of advice
