Author Topic: 3.2 Aux Belt  (Read 1794 times)
squattingbeaver
  • Nottingham
    • 3.2 MV6
3.2 Aux Belt
« on: 22 April 2011, 13:12:03 »
Hi Everyone
I had the aux belt shread itself a couple of days ago and it snapped the tensioner wheel, so today I thought I would tackle the job, replaced the tensioner pulley and went to put the belt on.
the belt I have is a 2020mm 6 grove but it seems to be too short, I just cannot get it over the last wheel with the tensioner fully released. It is almost like I need a belt a little longer, I spoke to my local parts guy and they do have a 2030mm but I just wanted to see if anyone has any thoughts and tips on this.
I am assuming I have routed it correct as I have used the picture off the forum link below.
http://www.omegaowners.com/forum/YaBB.pl?num=1292585707
Any help or comments would be appreciated.
Pete
Re: 3.2 Aux Belt
« Reply #1 on: 22 April 2011, 13:14:42 »
There are two V6 aux belts, for Air-con & non-airon  :y
squattingbeaver
  • Nottingham
    • 3.2 MV6
Re: 3.2 Aux Belt
« Reply #2 on: 22 April 2011, 13:18:23 »
Thanks for the reply, the 2020mm is listed as the one with Aircon but still wont fit, how easy should it be to put the belt on once the tensioner is full relased off? this one wont go even with trying to leaver it.
Pete
Re: 3.2 Aux Belt
« Reply #3 on: 22 April 2011, 13:22:56 »
Did you route it like this?
squattingbeaver
  • Nottingham
    • 3.2 MV6
Re: 3.2 Aux Belt
« Reply #4 on: 22 April 2011, 13:26:49 »
Yes but when routed and the tensioner fully off the belt would go about 3/4 across the water pump and no amount of leavering would get it on, I checked all the other pulleys and the belt was on correct.
Pete
Re: 3.2 Aux Belt
« Reply #5 on: 22 April 2011, 13:34:35 »
That should be ok, seem to re-call if its on that much, once turned over/started it should sort itself out  :-/
« Last Edit: 22 April 2011, 13:35:23 by tunnie »
squattingbeaver
  • Nottingham
    • 3.2 MV6
Re: 3.2 Aux Belt
« Reply #6 on: 22 April 2011, 13:45:43 »
Make that about half way over then, it wont stay on itself. its at the point it will not go over..I am going to give it half an hour and then try again.
squattingbeaver
  • Nottingham
    • 3.2 MV6
Re: 3.2 Aux Belt
« Reply #7 on: 22 April 2011, 19:00:20 »
Well its still the same, any tips or andvice on how to get over the water pump?
Re: 3.2 Aux Belt
« Reply #8 on: 22 April 2011, 19:19:04 »
Can you get someone to hold the tensioner in the right place,leaving you both hands free to try to get it on properly? :-/
Re: 3.2 Aux Belt
« Reply #9 on: 22 April 2011, 19:33:50 »
Pete
My car is a 99 3.0 but I've just had a look at mine & thats a 2020 too. Although it was a snug fit, it still fitted. You sure you've got it fully fitted into the crank & A/C pullies  :-/
    • 530D M Sport, 330i Coupe
Re: 3.2 Aux Belt
« Reply #10 on: 22 April 2011, 19:55:53 »
Is the belt from VX? Autovaux ones have been known to be too short in the past.
bobbertbear
  • perth
    • 04 omega 3.2 ex plod
Re: 3.2 Aux Belt
« Reply #11 on: 23 April 2011, 14:02:12 »
did the belt shred itself because it was old,or has there been anothere problem,mine shredded the belt and i found the crank pulley had started to split,the bit that the belt runs on was moving out towards the raditor throwing the belt out of line,worth checking.
