Author Topic: Front end rebuild  (Read 3533 times)
venom
  • South Moreton, Oxfordshire
Front end rebuild
« on: 13 April 2011, 10:57:24 »
I'm rebuilding my steering & suspension on the front.
I have got already
2x  new complete struts with springs
2x  new lower wishbones
Need to get
2x long tie rods (tie rod at both ends)
1x center link rod
1x drop link ?
1x steering idler arm
2x anti roll bar rubbers
Is there anything I've missed out  :question
Cheers
Ken
Re: Front end rebuild
« Reply #1 on: 13 April 2011, 11:33:22 »
I have got already
Need to get
1x center link rod
1x drop link ?  2
Cheers
« Reply #2 on: 13 April 2011, 11:40:55 »
Top shock mounts?
venom
« Reply #3 on: 13 April 2011, 11:43:39 »
I have got already
Need to get
1x center link rod
1x drop link ?  2
Cheers
Cheers on my old mercs there was only 1 drop link & looking at a pic of the underneath I could only see 1 but thought it might of had 2
Ken
« Reply #4 on: 13 April 2011, 19:10:16 »
If by drop link you mean the arm that connects the steering box to the centre tie rod, its the pitman arm ?iirc and there is only one.  :y
If however you mean the rods that connect the strut to the anti roll bar, then there are 2, one each side. :y
When you say new struts and springs do you mean brand spanking new or new to the car?
If new to car then a waste of time and effort imho. Also as Chris said re top mounts, they're cheap enough and easy enough to change, assuming that you're assembling the struts.
venom
« Reply #5 on: 13 April 2011, 19:52:15 »
Top shock mounts?
Yep got them  :y
Ken
venom
« Reply #6 on: 13 April 2011, 20:00:55 »
When I say new I mean new to the car, they came off of a low mileage car from Steve at Omega spares, Heathrow & It's the drop link from the strut  :y
Ken
twiglet
  • Norwich, Norfolk
« Reply #7 on: 13 April 2011, 20:24:45 »
Please don't mind me asking, but why are you changing so much of your suspension?
Is it all completely shot?  :-/
venom
« Reply #8 on: 13 April 2011, 20:36:34 »
Well sort of, the N/S wishbone needs replacing so that means I've got to change the O/S one.
O/S shock is leaking so again need to change the N/S one & I'm recovering from an operation on my right foot so cant stand for long periods so thought I'd just change the whole unit so I don't have to break the old ones down.
Two of the tie rod boots leaking a small bit so I decided to change it all before the MOT in 6 weeks so I don't have to replace the others in a few months.
Ken
« Reply #9 on: 13 April 2011, 22:32:48 »
While I sympathise with you predicament, but I can't help but think that s/h is a bad idea. :-/
I recently did a similar amount of work on mine, the prices as follows:
2x vx struts, £75 ea, £150
2x pattern top mounts £15 ea, £30
2x pattern wishbones with drop links £45 ea, £90.
Total £270. plus a few nuts and bolts. Oh and an afternoon or two. :y
venom
« Reply #10 on: 13 April 2011, 22:46:18 »
It's only the struts that are S/H & guaranteed & I can find anyone with a problem with Steve's stuff so if they are no good I'll buy new, everything else is Vauxhall dealer bought
Ken
« Reply #11 on: 13 April 2011, 22:59:50 »
Can't really argue with that. :y
Was only thinking about the possibility of having to do the job twice.
venom
« Reply #12 on: 14 April 2011, 11:43:06 »
Ordered the remaining parts from All German car parts & all made by lemforder, a great service & guarnteed for 2 years  :y
Ken
venom
« Reply #13 on: 23 April 2011, 16:43:46 »
Changed all the front end yesterday & had it tracked up today & my god it's like driving a different car  :y :y :y it's now so smooth on the road it's brill   :) :)
Ken
Bent valve
« Reply #14 on: 23 April 2011, 18:41:47 »
How did you set the camber up?
Page created in 0.026 seconds with 16 queries.
