Pages: [1] 2 3  All   Go Down
Author Topic: coolant disappearing(but don't know where)  (Read 4545 times)
moggy
  • hartlepool
    • vauxhall omega 3.0 elite
« on: 13 April 2011, 20:13:01 »
Hi guys just a quick question.On Monday this week my coolant check light came on.I took the top off the tank and it was empty,i put in about a liter just to the line on the tank.This morning it was empty again,the thing is no sign of any water on the floor or engine.I even left it running for fifteen minutes when i got to work,looking under the car and in the engine compartment.Its been sound since daz and pete did my cam belt change 18 month's ago.Any advise much apreciated Moggy  :) :y
Re: coolant disappearing(but don't know where)
« Reply #1 on: 13 April 2011, 20:13:53 »
Is it around the 1998 mark?? ::)
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #2 on: 13 April 2011, 20:14:54 »
HBV is a good candidate as it leaks at the back of engine and coolant runs to hot exhaust so nothing will end up on the floor. Does it smell like that?
twiglet
  • Norwich, Norfolk
« Reply #3 on: 13 April 2011, 20:15:39 »
Heater Bypass Valve?  :y
moggy
  • hartlepool
« Reply #4 on: 13 April 2011, 20:19:29 »
James date of first registration 1995,whys that mate :y
« Reply #5 on: 13 April 2011, 20:20:46 »
98 models had some problems with the NS head gasket leaking in rear corner
It's not that common, but can happen on any model with poor coolant servicing
Yours likely to be much more simple  :y
« Reply #6 on: 13 April 2011, 20:22:19 »
Header tank cap / neck ???  cap has a relieve valve in it that can fail.. neck can develop hairline cracks .. either will drop the pressure and cause the coolant to "boil"   ie .. evaporate....  much faster.
moggy
  • hartlepool
« Reply #7 on: 13 April 2011, 20:28:12 »
Kcl there is a bit of a funny smell, but i cannot describe it mate.BTW its not the wife ;D :y
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #8 on: 13 April 2011, 20:29:59 »
My money is still on the HBV. You might even be able to see it with plenum and scuttle on  :y
moggy
  • hartlepool
« Reply #9 on: 13 April 2011, 20:30:52 »
James,should i have changed the coolant in the last 18 months :-/
moggy
  • hartlepool
« Reply #10 on: 13 April 2011, 20:32:53 »
Kcl,where abouts is it :y
« Reply #11 on: 13 April 2011, 20:40:07 »
http://www.omegaowners.com/forum/YaBB.pl?num=1193594464
kcl
  • Finland
    • Volvo V60 D4 -14
« Reply #12 on: 13 April 2011, 20:41:40 »
That should give an idea http://www.omegaowners.com/forum/YaBB.pl?num=1181719948
chrisdb
  • Chesterfield
« Reply #13 on: 13 April 2011, 21:04:43 »
Hmm... with the strange smell my money would be on the heater matrix. Check if your front carpets are soaked.
TC Card, will buy parts for members near by. V6 Camshaft locking kit can rent out to members at club rates.
moggy
  • hartlepool
« Reply #14 on: 13 April 2011, 21:19:01 »
Thanks Chris i wiil check in the morning :y
Pages: [1] 2 3  All   Go Up
Page created in 0.023 seconds with 16 queries.
