Author Topic: A couple of questions . . .  (Read 3527 times)
Nickh
« on: 24 April 2011, 20:48:04 »
Can I have some advice please ?
This is on an Omega 2.2 GLS on a '52 plate.
1. The air con system on my Omega does not get cold . . bit of a pain in the recent hot weather.
Is there any quick and easy way of telling whether the compressor is knackered or if the system just needs re-gassing ?  :D
2. I've gone mad  ::) and bought a pair of second hand fog lights, along with a replacement light switch with the additional button. I've checked the existing wiring and the loom appears to be in place for the feed to the lamps. I've ordered the mounting clips for the lights from my local Vauxhall dealer. Is there anything else I will need . . relay etc. ?
Thanks in anticipation,
Nick
Re: A couple of questions . . .
« Reply #1 on: 24 April 2011, 20:58:33 »
Best to go to an aircon regas specialist, as they test the system for leaks etc. before regassing it. If its leaking the dye they use will show where its leaking from. If it isnt leaking - gas in, job done. :y
Foglights - not sure if they are simple plug and play or not. :-/
« Reply #2 on: 24 April 2011, 21:10:06 »
2. I've gone mad  ::) and bought a pair of second hand fog lights, along with a replacement light switch with the additional button. I've checked the existing wiring and the loom appears to be in place for the feed to the lamps. I've ordered the mounting clips for the lights from my local Vauxhall dealer..... Is there anything else I will need . . relay etc. ?
I think you're going to need a relay in the fuse/relay ...  :-/
I'm going off when I was playing with my Manta B  ............ many moons ago  ;)
« Last Edit: 24 April 2011, 21:10:39 by Andy_B »
joff
  • swindon, wilts
  • Discovery TD5 ES
    • Drives the wife mad
« Reply #3 on: 24 April 2011, 22:01:18 »
There is a few higher spec miggys being striped on here at the moment why not get all you need from them and not pay full price from dealers for your parts. Job done  :y
« Reply #4 on: 24 April 2011, 22:22:10 »
No relay needed. Fuse #16 powers the fogs
Nickh
« Reply #5 on: 24 April 2011, 22:28:13 »
Brilliant !
That's what I needed to know . . thanks RobG
Nick
« Reply #6 on: 24 April 2011, 22:28:18 »
Good idea Joff. My foglights have been sold,  but that RobG character might have a pair. ;)
« Last Edit: 24 April 2011, 22:28:46 by albitz »
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #7 on: 24 April 2011, 22:29:35 »
Not done this job myself but are they plug and play Rob if you have the loom in place and the switch. It's to late at night and my glass is going down! all miggy's come with fog lights yes? :-/
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #8 on: 24 April 2011, 22:31:57 »
that's fog lights on the rear as stanard :-/
« Reply #9 on: 24 April 2011, 22:34:08 »
Foglights are plug & play as long as the loom is there.....and yes, rear fogs are standard
« Reply #10 on: 24 April 2011, 22:35:29 »
Only one Albs, plastic crappy bulbholder gone on t`other
Geobond
« Reply #11 on: 24 April 2011, 22:37:08 »
Admin Edit: Sorry, no discussion of illegally obtaining copyrighted material.
« Last Edit: 24 April 2011, 22:51:43 by Kevin_Wood »
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #12 on: 24 April 2011, 22:42:52 »
I have a hard copy but does not do F/L 2000 on but i do use this forum as it's a lot better than the book :y
Darth Loo-knee
  • Death Star
  • Jammie smells of Pooh....
    • TIE Fighter
« Reply #13 on: 24 April 2011, 22:47:28 »
You need to be deleting that mate we can not have posts distributing copyright material :-?
I will pass it on so if you could delete it please.
Thanks :y
« Last Edit: 24 April 2011, 22:52:08 by Kevin_Wood »
joff
  • swindon, wilts
  • Discovery TD5 ES
« Reply #14 on: 24 April 2011, 22:54:28 »
well done Daz :y
