Author Topic: Fault Code  (Read 1256 times)
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Fault Code
« on: 25 April 2011, 13:23:10 »
Hi, I am getting fault code 0430 assuming i am reading it right (10 flashes, then 4 then 3 then 10) but i cant find this code listed in the maintenance section...Does anyone recognise this code, by memory maybe?? Thanks... :)
sandune
  • Essex Southend
    • 2.6 Omega Auto
Re: Fault Code
« Reply #1 on: 25 April 2011, 13:34:02 »
Hiya P0430 catalyst system efficiency below threshold bank 2
 hth :y
SJKOO01
Re: Fault Code
« Reply #2 on: 25 April 2011, 13:37:03 »
Basically means that the PreCats on the manifold are on the way out, not a big problem to worry about, see the link below which maybe of help  :y.
http://www.omegaowners.com/forum/YaBB.pl?num=1253462747
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Re: Fault Code
« Reply #3 on: 25 April 2011, 17:50:54 »
Thanks for the responses, and Help!! Appreciated!! :y
Re: Fault Code
« Reply #4 on: 25 April 2011, 18:01:55 »
Oh it's there alright, along with 0420.
Take it for a damn good thrashing. Might help if it's recent/marginal.  ;)
T-rev
  • Grays Essex
    • 2002 Omega 2.6CD
Re: Fault Code
« Reply #5 on: 26 April 2011, 20:22:43 »
Yep Chris, you are correct it is there, i should have gone to spec savers...Will probably replace rather than take the link option given...Just aint got the time to do!! :y :y
