Author Topic: Temp gauge sender on a X22Z  (Read 1410 times)
Jan Suhr
  • Nyköping, Sweden
    • 2 Omega Caravans 3.2 V6
« on: 26 April 2011, 16:01:07 »
On my Omega the temp gauge died the other day. It doesn't show any temp at all.
My guess is that the sender is bad.
Can someone tell me where to look for it?
Thanks
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
Boiler Man
  • Sale, Manchester
Re: Temp gauge sender on a X22Z
« Reply #1 on: 26 April 2011, 17:28:51 »
Try giving the speedo a tap with your knuckle.
Sometimes works with mine, daft I know, but mine is something to do with the connection at the back.
Omega 2.0 DTI GLS Estate 99 Gold & Omega 2.2 DTI CDX Estate 03 Silver. Just need a Bronze one now for the full set.
« Reply #2 on: 26 April 2011, 17:32:32 »
Thanks
Jan
I'm not well up on 4 cylinder cars, bit I think the sender is at the back of the engine next to the ECU's temp sender. You want the one with just one wire to it. (RobG will find a picture for you  ::) ;))  If you  remove the wire & ground it (connect to earth/negative side of the battery) the gauge should go all the way to hot) You could just have a bad connection.  :y :y :y
HTH
I found a picture  :y :y :y This actually a 2.0 with a DIS, but yours is similar  :y
« Last Edit: 26 April 2011, 17:38:47 by Andy_B »
plym ian
  • Plymouth, Devon
    • 2.0 insignia elite tourer
« Reply #3 on: 26 April 2011, 21:35:22 »
mine stopped working the spade connector had fallen off so i just clipped it back on bit of a mission to do as it is right at the back of the engine :(
Jan Suhr
  • Nyköping, Sweden
« Reply #4 on: 27 April 2011, 17:44:50 »
That usually works when the instrument lights go out.
I'll check the connection and try to ground it and we'll see whats wrong.
Thank you guys  :y
Jan
Jan Suhr
Stockholm, Sweden
www.protouring.se
